The high and low side pressures are a little under 100 lbs static. I have not running pressures since the pcm won't let the compressor turn on.
Right after the ac quit, I starting getting p00351 code and misfires on cylinders one and two. Truck basically goes into a limp mode if you try to drive it. I have replaced all coil packs and plugs when I did the timing chain, tensioners and phasers back in April of this year. The truck ran great until just last Thursday when the AC failed it developed the misfires. This is leading me to believe that the pcm is starting to fail. It seems too coincidental that all these functions would fail at once unless there was a common source for the issues. Could be wiring too I guess.
