The codes for the lamp flashing were not given
Lamp Fault Codes
When the restraints control module (RCM) detects a system fault, it will cause the air bag indicator to flash a coded sequence: a lamp fault code (LFC). The code is two digits. The first digit is flashed with a 0.5 second interval between pulses. There is a 2 second pause before the second digit is flashed, which also has a 0.5 second interval between pulses. There is a 5 second pause between each display of an LFC.
Each LFC is flashed five times after which the air bag indictor will remain lit for the remainder of the key-on cycle. If there are multiple LFCs, each LFC will flash in order of priority.
Diagnostic Trouble Codes (DTCs)
While the lamp fault codes (LFCs) are an indication of a general concern in the passive restraints system, the diagnostic trouble codes (DTCs) are more specific. The DTCs can be retrieved from the restraints control module (RCM) with a scan tool via the data link connector (DLC).
