367KIX
The radio has been dead on my X for some time, including no clock on the display when its turned off. I do hear some possible relay clicks under the hood with the ignition switch turned to accessory. Triple checked fuses and am sure power/fuses is not the issue, at least for the head unit. I finally purchaced a new JVC head unit and wired it up. The new stereo lights up very pretty, but no sound through the speaker system. I've verifed with a test speaker that the new unit is producing audio, so I'm assuming the original head unit and/or amplifier are broken, preventing audio from getting to the speakers.
I've looked through the other threads and haven't seen anything specifically about which 97 Expedition configurations have a "hidden" amplifier. Mine says "Premium" on the front two speakers, but it seems to be a regular four speaker system, with no guarantee of a hidden amp some place. With the head unit out, I did see down lower, behind the dash, what looks like the heat sinks for what I think might be an amp, but I can't verify its an amp via wiring traces without tearing out the dash.
Any suggestions or experiences on if this car should have an amp and if what I described is an amp for sure, would be appreciated. It looks like I'm out of luck on fixing the tunes, except for an amp replacement (if needed) or rewiring to the speakers to bypass it altogether.
