Another window?
aka rotten
Ga.
Yesterday outta blue passenger side window just quit working.Not had any problems such as slowness,noise anything.Does not work with either switch.Sounds to me like motor time but mabee someone knows a secret for an old man that i dont know to try.I dont own a meter so any ideas?And if worse case are they hard to replace?i,m in wheel chair but not afraid to try few thing if nessesary.By the way its 2000 mod.Thanks,Paul
RobertNol
Hernando, Fl
Is it stick up or down?
Reason i ask is because my 99 window went down and would not come back up but i could still hear the motor trying. I pulled the door panel off and the window had come of the track! It was a pain in the butt to get my hands in the for but a little while later and some jiggling i was able to get out back on track. Hope this helps.
A
aka rotten
Ga.
Thanks for the responce,The window is up and i got out this morning and also checked passenger door switch and it does nothing either.I,m no mechanic by any means but that pretty much illimanates switch problem dont it ?and points to window moter?Thanks,Paul
RobertNol
Hernando, Fl
Yeah if all your other windows work and the window is up it should be on track. When you push the switch can you hear the motor?
But yes i would say its probably the motor that has burnt up.
FordandPolaris
Saint Cloud, MN
I had my window motor go out on me this last summer. It is a little tricky and is much easier done with two people, but is possible with one. They are also pretty cheap. Cost about 25-30 bucks for the entire regulator assembly. Best to buy this as opposed to just the window motor, so as not to have to mess with the spring, etc. One way to check the motor is run two wires from the battery to the motor, and try to run the motor. It runs on reverse polarity, so if it doesnt go one way, reverse the positive and ground wires on the motor to try and run it in the opposite direction. If you still get nothing, then replace the regulator. If the motor moves the window, look at the wiring between motor and switch or the switch itself. Here is a video of how to remove the regulator if you need it. This is what I used to replace mine.
How To Install Replace Window Regulator 97-02 Ford F-150 Expedition 1AAuto.com - YouTube
