Anti-Theft Unexpededly Activated
tpndrcn
Morrison, Il
Last night after my family and I stopped into the pet store and came back out my 08' Expy wouldn't start. Initially I thought my battery was dead and had a individual try and jump me with no luck. Then I had him take me to the local Farm and Fleet to get a new battery still with no luck. My wife then noticed that the anti-theft light was flashing when turned the key to run position. I am using the factory keys and haven't changed since I bought it about a month ago. What triggered the anti-theft??? Its being towed to the Ford Dealership now as we speak to be looked at.
tpndrcn
tpndrcn
Morrison, Il
Dealer is telling me that pinpoint test is pointing towards a bad P.A.T.(Passive Anti-Theft) transceiver and if not that then the cluster!!
tpndrcn
tpndrcn
Morrison, Il
DF5.4 yes i did try my other factory key and it didn't work either. It says to try different keys or, wait 15 mins and it will reset. I also unhooked the battery and still no results. I gave the dealer the go ahead to replace the P.A.T.s transceiver today so i will keep you all updated. It looks like the Gen 2 Expys had this condition too!
tpndrcn
tpndrcn
Morrison, Il
Just received a phone call from the dealer , the transceiver was bad ,however it didn't fix my no start issue. After further testing it revealed that the smart junction box is bad, so another $260 but hopefully will have it back tomorrow. I asked them to find out from the tech what may have caused this. I was a previous Ford Tech but wasn't the diag guy so its beyond my scope.
Bedrck47
Elizebethtown, PA
I wouldn't be surprised if the dealer were to inform you that the SJB didn't solve the problem and the next item that would need to be replaced is either the PCM or the Inst. cluster.
tpndrcn
tpndrcn
Morrison, Il
roxy1225, Fortunately the Smart Junction Box fixed the issue!, $530 later. My question would be what caused it all to go bad. I read that the junction boxes had issues, and also that leaking windshields can cause them to go bad. To the best of my knowledge this wasn't an issue , but maybe I was the luckly one with a faulty S.J.B.
Temple, Georgia
The possibilities can be just about anything. If there are logic circuits on the SJB then overvoltage or excessive current from a jump start can take ic's out. Not saying it did - just a possibility.
Poor design, poor manufacturing quality control, inferior parts etc.
Did they return the old parts to you?
Bedrck47
Elizebethtown, PA
thank you for the update
Glad its fixed and running
Would agree with what stamp11127 says about causes
tpndrcn
tpndrcn
Morrison, Il
No I didn't ask for the old parts, and I can agree with what stamp11127 says because with my past experiences as a tech we replaced parts as neede that just went bad, for unforseen circumstances. I found some information on SJB having issues. I am glad to have it back, I love driving it!
Bedrck47
Elizebethtown, PA
what was interesting was that you were first told it was either the PATS transceiver or the Instrument cluster and when the transceiver was replaced you were then told the SJB needed to be replaced.
I would question if the transceiver was truly bad or if it was the SJB all along.
Some information that I have found is that the SJB is also referred to as the GEM. Found that information in the 2009 workshop manual
tpndrcn
tpndrcn
Morrison, Il
I wonder about the PATS transceiver actually being bad too, because they said the pinpoint test leads through it and it was saying its bad, however if the sjb was bad and wasn't supplying it , it would fail test in my opinion
