Any source for 2015 expy 3rd brake light gasket?
sixstring
Florida
Does anyone know where I can buy a 3rd brake light gasket for a 2015 expy??
I'm not having much luck.
Thanks.
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Well, I replaced my entire 3rd brake light assembly with an LED version on my 011 EL ($34 from da Zon) a while back & it came with a new gasket, but I'm not sure if it is available separately or not....
But if it is, then any of the reputable places should have them, like da Rock, Tasca, FordPartsGiant etc....
JamaicaJoe
Oviedo FL
I did same on my 2013. The OEM melted and bulbs kept popping. I bought an aftermarket LED version with foam gasket. The OEM design is awful.
Moeman
Greenville, SC
Could also get yourself some foam gasket material and cut it yourself, some silicone would also do the trick and not be too difficult to remove if you needed to take the part off again.
DeafBringer
Washington
Same, 3rd brake light melted on 2 expeditions and couldn't replace the bulbs because the housing was too warped. replaced with LED lights on both and had no problems.
On the 2012 I also wired in a rapid flash to solid for when the brake is applied. Super easy and cheap mod to grab more attention for drivers behind you.
