Anyone have the projector lights?
ELVATO
Orlando, FL
Usually, the headlights assemblies will have the harnesses to split up the 9007/8 plug into whatever the light uses.
Granted, if you go from 9007 to a housing that is dual beam, and you get an HID kit, you'll have to do some wiring, since I think the MFS shuts off the low beams when you go to high beams.
I must say, the lights linked aren't horrible. I, too, am not a huge fan of the extra lighting. One of these days, I wanna do a bi-xenon retrofit (FX-R or TL projector).
locosol96
Maryland
I'm going to try and take a pic of the truck today so you can see them.
The high beam is the same as factory. The headlights come complete with all bulbs needed. As the turn/parking light section is clear, they even come with a 3357 Amber bulb.
There is no harness conversion needed. The factory Expy headlamp assemblies are "plug and play". The power harness on the back of the aftermarket ones are the same as factory. These literally are plug and play. The bulb for the low beam is an H3 halogen. I got an H3 6000K HID to replace it. The whole thing, including running the wires for ballast (plus I added a relay and resistor to power the lights directly from the battery) took 2 hours. If all you're doing is swapping out the factory headlights for these without doing an HID conversion, then it would take 30 minutes or less.
I don't know what a picture of the light cutoff would do. It's totally subjective anyway. I can tell you I live in a rural area (farm country on MD's Eastern Shore). I leave at 4:00am for work. It's dark. Even with the standard light output (before I added the HID a few days later) I was happy with these. Like I said, I had to aim them up slightly, but that was to be expected. I seriously doubt the hardworking Tawaiinese folks who made these have an Expy that they test the aim out on every set they build. So, I figured a little adjustment would be needed. Overall, quality is decent, fit and finish are pretty good (same lines/gaps as the factory ones) and I liked that these were true "plug and play". I really like that they are a flat black finish. I think once I get my tan trim and upper/lower grills painted black, these will really add to that look I want.
I've built custom projector assemblies for other cars before (all three Hondas, a VW, and my Dodge truck). Are these as good as the set I made with the S2000 projector lenses and the Phillips HID kit? No. But then again, that kit wound up costing me about $375-$450 (when you figure in my time and labor).
You can get a pair of Expy headlamp assemblies cheap and the actual process of converting them is not hard, just time consuming as you have to be very careful. I'm fairly **** and would have preferred to do that. I just don't have the time. Besides, this truck has 120,000 on it and will most likely be replaced in the next 18 months or so with a new Expy EL Limited. I'm going to wait to do a top-notch projector re-fit on that.
Now, if anyone lives reasonably close by and wants to bring their truck over for an HID re-fit or add power folding mirrors to your 03-06 Expy, we can talk!
F
FordRacing1
Tennessee
keep in mind i do have the 2000 model and not the newer body. but i cant bring myself to spend $900 on a retrofit. It isnt worth it to me. I want to be able to see better but not that much better. As long as i can buy a projector and strap a hid kit in it an it look decent i am happy. im not asking for cream of the crop. just decent. something better than the milky headlight assembly that i currently have
locosol96
Maryland
Here's my Expy with the lights.
I don't know anything about the first Gen body style. I've heard that F-150 lights are a swap out, but I have no first hand experience.
$900 for projectors is ridiculous.
2blackfordrides
POULSBO,WA
the projectors i have are off ebay also..... i love them.... and ive had them on my 99 xlt for almost three years, havent even replaced a bulb and its the same style as ur 2000..... no fogging, no leaks, no nothing..... i agree with above comments..... buy off ebay if u need economical and u will have extra xash and be happy.... i have people flash their hi beams at me everytime i drive mine with the low beams..... the high beams easily double if not triple ur visibility......
ELVATO
Orlando, FL
Have you aimed your lights? Shouldn't have people flashing you all the time...
F
FordRacing1
Tennessee
I guess what im really wondering is, when you put the HIDs in the projectors or even leaving the stock halogen in. Is the light scattered all over the road or does it pretty much do what a projector is supposed to do and have a decent cut off and light up the road. I drive down dirt roads alot at night just to drive and I run the risk of slaughtering a small animal if I dont have good light output and I dont have to tell anyone that the stock headlights suck big time. Could someone maybe take a picture at night of the road with them on? either HID or not. with the ebay projectors of course. I would really appreciate it
2blackfordrides
POULSBO,WA
my lights are aimed all the way down but the truck sits high...... and i will try to take a pic on the road soon..... i drive in upstate ny in the stix to my folks house and its pretty much all dirt roads.... the light does what a projector should.... also they sell a projector fog kit for around 70 bux i think that imma buy next week ( and the hid kit to match them)... i would imagine that would help ur cause too..... i will do my best to get a pic this weekend....
F
FordRacing1
Tennessee
Thanks bro I appreciate your help
joezek
psl, FL
I bought an HID retrofit kit one time on ebay for like $40. They looked awesome for about 10 seconds, then as soon as they're warmed up they flicker like a candle. You get insane headaches trying to focus and drive at night with both lights flickering non stop. I tried all the nonsense kits to rewire and give more direct power from the battery to the HID ballast etc, I even tried using capacitors to stop the flickering, but NOTHING helped at all. Apparently a lot of cheaply made ballasts will do that, they flicker after warm up because of a poorly designed power supply.
locosol96
Maryland
That's the problem with the cheap kits. They are inferior and many times, you get what you pay for. I got mine from HIDonlinestore.com. True plug and play with no flicker, strobe or "waiver" (as some call it). I've bought kits from 5 different places for different cars, and I have been happiest with these guys. Just my $.02.
NC-Expy
Apex, NC
my .02 is I dont care for projectors... bad light output... but if you haven't seen them yet look for the R8 style lights for expys/F150s... I've had mine in for a few months now with HIDs and no problems at all.... somewere I posted a thread about "R8 lights in" shows some good pics of mine... again my .02.. everyone has their opinion....
are those R8 lights plug and play?
F
FordRacing1
Tennessee
yeah screw ebay hid kits. the lights are ok to buy but most every pair of HID kits ive bought have been junk. DDM tuning supposedly has some good ones. havent bought any though. im more worried about the way the projectors work with the hid than the Hid kit itself. I want to know if the projectors put out good light
Newport News, VA
i have spyder halo/led projectors...havent drove at night yet so i dont know about the light output...put from what i see just playing with them...same as stock...so please post pics of the HIDs with projectors so i can see how they look and switch mine.
as far as DDM...WHOISMOOTOO and someone else bought from them and all suggest buying the 35 watt HIDs from DDM and they love them...
walnuts4x4
Watertown, NY
R8 lights plug and play....
and LOVE my 39.99 HIDs from ebay... both headlight and foglights...
Newport News, VA
they dont make the R8 for my year...has anyone turned their halo/led projector lights to HID? i looked at mine before i installed them and where you would insert the bulbs...they looked like they were wired/screwed...something...they were different...
ELVATO
Orlando, FL
Some aftermarkets can't be converted to HID because the bulb won't fit in the projector housing.
Newport News, VA
well that sucks!!! so now the question is....do i waste $40 plus shipping to see if they can be converted or not....that dear forum...is the question
