Are there supposed to be trim pieces under the bars on the roof?
Jace
Utah
No covering trim on my '19 limited max special edition. I actually noticed this when I was doing my final inspection and thought it was odd... A magnetic stealth right next to it was the same way so I figured it was normal.
This is looking back from the passenger side just above the rear window.
nate6966
US
I still don’t see it on mine anywhere. But I believe you. Maybe because mine is white it is less obvious?
Yours is better. I concede.
Same parts, but yours was assembled with better alignment
Bow512
TX
My 2018 limited has the trim pieces. 6/18 build
duneslider
Utah
My 2019 XLT has black plastic trim pieces under there. And if I were 8 feet tall I could see that the roof panel is welded to the side panels but since I am only 5' 10" I can't see the welds unless I get a ladder.
F
fishrising
CT
Thanks all! Now to see if I can order the pieces for my 19XLT.
mlself
