Auto-lock and master window controls
logoster
My Car/PC
Hello everyone,
my family's main vehicle (in signature) has a few problems (which are more just annoying problems then anything else) and was wondering if you guys might have some idea on how to fix them
first problem is that the vehicles auto-lock at 5MPH doesn't seem to be activating (the door ajar light also likes to stay on, could that be what's causing it to not auto-lock?)
the second problem is that the master window controls seem to refuse to control the rear passenger window on the drivers side
any help will be appreciated
L
logoster
My Car/PC
it is programmed to auto-lock at 5MPH, i know that for sure, although looking in the owners manual it seems that it's because of the door ajar light on the dash being on, guess it's time to go wd40 the latches
so now the only problem is the master window controls not working with some windows
Bedrck47
Elizebethtown, PA
you may have a bad door ajar switch to check this you would need to remove the door panel then disconnect the switch connector and place a jumper on the connector if your light goes out then replace the switch
as for the window switch use electronic spray cleaner from the inside of the switch
or replace the switch to test if the switch you could jumper the switch and you would need the wiring diagram for that
let me know if you need the diagrams
