automatic transmission heating
manuelb
florida
I have a 2020 Ford Expedition and the transmission heats up when I'm in traffic, the temperature gets between 225 very quickly and can reach 235 F but when it reaches that number I stop driving, on the road when I'm going fast it doesn't go up and down rather the temperature. I don't use the trailer.
I have already read about changing the thermostat, somewhere I have read about a cooling aid that they install in the transmission, DOES ANYONE HERE HAVE THE SOLUTION OR DO THE SAME HAPPEN TO THEM?
JimmyM
Boston, MA
235!? I've never seen those temps slowly pulling a trailer uphill during a traffic jam. It's like it's not circulating trans fluid to the heat exchanger at all. What are your engine coolant temps?
Hellwig
it looks your vehicle has the metal bottom thermostat and it is seized. Replace it with a redesigned plastic plate thermostat, like RT1258.
M
manuelb
florida
I changed the thermostat that opens at 160f and now the temperature reaches a maximum for now at 185f, I have driven 4 hours today, so far it has been a success.
The transmission does continue to fail me in speeds 1,2,3 and 4 but if I go slow it doesn't fail me much.
I changed the transmission oil and filter and it improved but not 100%.
Ford expedition 2020
