Auxiliary AC Relay
ebmp
sc
Hi,
Just purchased 2004 Eddie Bauer. The Rear ac motor is not blowing any air. Checked voltage at motor itself and was not getting any voltage. Could someone tell me the location of the rear ac motor relay? Any help would be greatly appreciated.
P.S.--In the process of getting a shop manuel.
Bedrck47
Elizebethtown, PA
Have you checked the fuses for the rear AC motor??
I have attached prints from the 03 expedition They are the same as the 04 prints
Hope they help
  • 52-02.pdf
  • 151-31.pdf
  • 52-03.pdf
  • 55-04.pdf
  • 52-05.pdf
E
ebmp
sc
Thanks Bedrck47 for the prints.
I have the EATC. I checked voltage, and I have voltage all the way to 12 BK/LG which is one side of the wires going directly to the fan. I checked it against chasis ground. Looks like the relay is pulling in. Looks like I need page 52-3 to follow the path.
Could page 52-3 be sent also?
Thanks. This has already helped tremendously.
E
ebmp
sc
Thanks Bedrck 47 for the additional prints. Was able to track down the path problem to the driver controlled auxiliary ac fan speed switch. None of the positions on the switch was actually allowing a path from load side of relay to gnd. Think this the only issue.
