Auxiliary Reverse Light Question
NC-Expy
Apex, NC
So I got a set of 55W reverse lights that I'm going to be mounting on my trailer hitch... my question for you guys is: can I go ahead and tap into my existing wiring for my OEM reverse lights? (brown and pink I think it is?)
Or do I need to go ahead and have a separate relay for them?
In which case I'd probably just wire them straight to the battery and then wire them to a toggle switch up front.
Remo
Hartford, CT
That's too many amps to tap into the reverse wiring. You should definitely use a relay; and I'd recommend a 3-way relay and switch set up (on, off, switched-on). This is much safer, more reliable, and you'd probably find it more useful/convenient.
If you didn't buy the lights yet, and are set on keeping the wiring as simple as possible, get some LED aux lights--they will draw significantly less amps. Those you could probably just tap into the reverse wiring for power.
Hope that helps.
Remo
Hartford, CT
One more thing, lol. If you have the tow package with the wiring harness, you could probably use that for power (rather than running all the way back to the battery). I'm not 100%, but that is worth investigating.
NC-Expy
NC-Expy
Apex, NC
I do have the tow package with the wiring, so I could just splice into that? That would make my life a whole heck of a lot easier...
Remo
Hartford, CT
I'm sure someone around here can pull up a wiring schematic for you...I'm pretty sure you can use it, though.
panda24619
San Diego
how are they being mounted? why not mount them where i have mine?
and they are on a switch. its fun to see some idiot thats tail gating you and accidently hit the switch.
edit: what the hell?! shaggy we have a problem. these are
and still they wont pop up. people just say im crazy!
NC-Expy
NC-Expy
Apex, NC
I'm bolting them on to my trailer hitch. They are real tiny lights and I'm not interested in putting these, or bigger ones on my roof rack so the hitch will be best for me.
panda24619
San Diego
what i would do is just tap into your trailer hitch lighting. thatll would best.
r98exp1
