richs fishes
08 Expedition EL with approx 116K miles. Bilstein 4600s (I think thats the number) were installed approximatley 15k miles ago. Something feels off with the suspension and I cant figure out what's wrong. Feels like the right rear wheel continues bouncing too many times after hitting a bump. Every so often I can hear a clunk when making a turn but cant pinpoint where its coming from exactly.
I thought I'd be looking at a bad strut, but I dont see anything leaking or any other reason to assume this strut with only 15K miles is bad.
Also thought it could be a bad ball joint somehwere. Got the rear end up in the air and nothing seems out of place. No extra slop or play in any of the obvious spots to look. Grabbed a bar and started poking, proding, and prying everywhere that made sense and nothing jumps out as being loose or worn bad enough to cause this.
Only thing that seems slightly out of place was the spring seemed like it could rotate a degree or two on the seat. Almost like its floating a bit when there is no weight on it. Could that be causing this and what might the fix be? Any other thoughts?
