Battery issues advice...
Discussion in '3rd Gen - 2007 - 2017' started by legendary70, Dec 6, 2018.
  1. legendary70
    legendary70 Member
    48
    23
    Oct 18, 2018
    TEXAS
    Hello all. Very knowledgeable people here....and that is why I am asking here. In the hopes I dont get flamed and get some advice. Ford family correct......:)
    i have a 2005 explorer. i noticed that when it started getting cold here in El Paso my battery would have a hard time starting up the car in the mornings. after about a week of struggling to start up the truck it died. one morning it just did not start anymore. I went to wal mart and got it exchanged since i had just bought it about 7 months ago. so i went ahead and put the new battery into my expedition and put the one in the expedition into my explorer. It never had issues when on my expedition. Well that was about 3 weeks ago and started to notice the battery again having a hard time starting my truck....well this morning it is dead again. I am not sure if it is the cold weather or what. what do y'all think?
    thx
  2. Munkiebunz3
    Munkiebunz3 Full Access Members
    36
    170
    57
    Sep 20, 2018
    Soviet Monica, Kommiefornia
    Putting an old battery in the car with battery problem doesn't help diagnostics. First check the battery voltage before starting. Then check that you are getting good charging current and voltage. Buy an amperage clamp if you don't have one. If that is not good then check your connections before replacing the alternator voltage regulator or the alternator. If you have a lot of buildup on your battery then it is likely a parasitic drain on the battery while it sits, causing a lot of off gassing when it charges. Use the amp clamp to check amperage draw while you pull fuses to isolate the circuit.
  3. 1955moose
    1955moose Full Access Members
    5,750
    1,176
    Nov 23, 2014
    Well that's pretty much what I was going to say! Your problem though, and this is kinda reaching, is not your battery. If you never had any starting problems with the bigger motor, more accesoried SUV, then swapping it into the smaller explorer, shouldn't cause starting problems. Check the amperage draw from Starter, and like Mr stated, voltage and amperage from alternator. Places like O'Reilly's or Autozones portable load testers should do all that. And their free.
    Munkiebunz3 likes this.
  4. legendary70
    legendary70 Member
    48
    23
    Oct 18, 2018
    TEXAS
    thx guys
  5. Munkiebunz3
    36
    170
    57
    Sep 20, 2018
    Let us know what the result is !
  6. poppie
    poppie Full Access Members
    68
    28
    Nov 29, 2010
    Wisconsin
    Your Alternator might not be putting out full voltage, get a static , engine off, Battery voltage reading with a digital volt meter that should be in the area of 12.5 to 12.7 volts , then start the engine and see of you have a voltage bump over the static reading in the area of 13.6 to 13.8 volts, any less and you battery will run down over time, more so with short trip's.
  7. CrAzYJoe85
    CrAzYJoe85 Member
    33
    Feb 16, 2018
    Apple Valley Mn
    I had a parasitic draw on a jeep I had once it was drawing from a tail gate sensor what you need to do is take a volt meter and check every fuse for current if it has current and its not suppose to when the vehicle is off then you may be able to narrow down your search for me I just unplugged the sensor and all was good
  8. inmanlanier
    inmanlanier Active Member
    33
    Jun 1, 2014
    Florida
    Clearly proper charge is key. As an FYI, however, temperatures where the battery sits have an impact on life. I see a Texas flag - we're lucky to get three years out of batteries ubder the hood in So. Fla. My Genesis on the other handlasted a long time in the trunk.
    iimagine and 1955moose like this.
Share This Page
