Battery Issues
Jrose091984
TN
Need a question answered. What would be causing a battery warning light to show on my 97 expedition...If you know the answer it would help alot cause im at a lost...
Lane24
technical advisor
Alberta , Canada
Bad Alternator, bad battery, dirty posts, bad cables, etc. etc. Is it draining while you drive? Like when you step on brakes, or use turn signals, or turn lights on? Then probably your alternator... Does it have trouble turning over? Give us a little more info, and we should have someone that will chime in and be able to help you.
J
Jrose091984
TN
its draining while it sits and runs and while u drive it....put a bigger battery in it cause the one that was in it was not big enough for the vehicle the battery terminals are good and clean and it really hasnt had an issue starting
tonydiv
technical advisor
Middle River, MD
I would check the above list first, and have the battery checked out. One dead cell can cause quite a bit of problems.
I picked up a small waterproof battery charger and installed it under the hood. Now, if the truck is going to be sitting for more than a few days, I just plug in the charger and it will keep everything topped off.
Lane24
technical advisor
Alberta , Canada
I'm gonna stick with my original thought too and say alternator. I couldn't drive 5 blocks without the battery draining a few months ago. Replaced the alternator and all was well.
Newport News, VA
go to autozone, pepboys or somewhere that can check your starting system...its FREE!!! takes a couple of minutes and your off
CARO'S98EB
florida
A simple test isto use a volt meterwith a good battery and eng idling should have at least 13.6v up to 14.4, if not alt is probably bad.
