Battery light?
Wal92tt
Riverview, Fl
Last month I disconnected the battery terminals before doing some work in the engine bay. Since then, the battery dash light stays on. The battery is only a few months old, the cables are on tight, I've removed, tightened, and I can't figure it out? Yes, the terminals and cables are clean. Is there a trick to resetting this light? My scanner shows nothing as well. Any thoughts....?
1955moose
Check the connection at the back of alternator. It's very possible you bumped something working on your engine. Are you still charging 14.2 volts? Or has that changed?
