Bent door panel
ELA V8
America
A friend and I took my driver's side door panel off to get a look at the wires. He tried prying the panel off at the top left corner, I caught him too late and now it isn't tight like the others. There's probably about an inch gap at the top left corner and down the left side. If you push it, it moves in. Nothing major, but it's been annoying me. Is there anything I can do short of buying a new panel?
99 Expy
Laramie, WY
Did one of your clips break off? If that is the case, then you can get them from a local auto store.
Newport News, VA
check out the junkyard for an EX with the same interior and take that panel...
walnuts4x4
Watertown, NY
you could try heating the inside of the panel with a hair dryer or low temp heat gun and try to "work" the plastic back into shape... I would heat the inside because if you burn or melt it... it will be hidden... just my .02
also are you sure everything is back together right.... no wires or anything keeping everything from attaching??
