Bilstein 5100 Lift Install
95cobby
95cobby
Bowling Green, OH
You don't want to go by his numbers being that you are a 2016. We have different spring rates than the 2018s hence the reason the 5100s for the Expedition are the same part number but give different lift possibilities for 15-17s compared to 18-19s.
I went to the regular old alignment shop and they had no issue aligning mine.
Yea taking ours to Christian Brothers.. they have a new Hunter laser machine and said they could do it. I will prolly give them the specs from Readylift just as a guide in case.
16plati
VA
And you said you were on the second ring for the fronts?
95cobby
95cobby
Bowling Green, OH
His sig says 2nd grove.. but that might also mean middle since bottom is stock.
Got it align and it drives great! Steering wheel is perfectly straight as well.
Black
Kentucky
Correct. Ring 2 which equates to 0.79” on the F150. Spot on 2” of lift for me. I was concerned ring 3 would be more than 3” and I did not want to tear it apart for a third time so I erred on the side of caution.
I wanted 2” not 3” I like a touch of rake and did not want it leveled.
WJD_xlt
socal
Going this route, if I went 3” lift up front I’m assuming I could run a 35” tire?
16plati
VA
325/60/20
I’d say electronic running boards and fender /wheel well modifications would be needed. Had to loosen and move my running boards back 1/2” and shave off an inch of my front wheel well on the fender to fit the 35s AND the 1.25” spacers with zero issues now
WJD_xlt
socal
I have fixed running boards so I assume that won’t be an issue. The fender well doesn’t sound like it’ll be too much work.
Thank you for the replies.
16plati
VA
Fixed you’ll most likely have to shave some of the plastic or whatever they are made of
Richie Hostetler
Youngsville, NC
I love how that turned out, but I'm confused. Is this utilizing the 5100s without the Readylift? I have 5100s on the way for my 2019 Expedition XLT 4x4. I ordered the part number for the Expedition. Thanks in advance.
Black
Kentucky
Hopefully as you should not run spacers on 5100s as you seriously risk bending your shaft since the body and shaft of the 5100 is longer to accommodate the lift that can be gained.
95cobby
95cobby
Bowling Green, OH
Correct, no spacers. 5100s only. Good luck on the install I’m curious what the front looks like with the Expy part numbers. Post pics when it’s all done!
1alembic
Fl
Richie Hostetler - I'm also interested in details on how your turns out. I'd also like to go with the 5100s but for simplicity sake, I'd like to get the full set for the Expy. So definitely interested in pictures.
sanman28
SW MO
So if the rear exp 5100's are at max height, and the front F150 5100's are at "stock"......if you wanted more lift in the front, just go up the middle to top ring....but what about the rear? How can you gain extra height there to maintain level?
16plati
VA
You can put a 4600 on it and Readylift spacer to get 2” in rear. If you go past the second ring on the F-150 5100s you’re venturing into above 3” of loft which is not recommended. Gonna tear that suspension up
sanman28
SW MO
Ok so the middle ring on the f150 fronts is 3"+.......so stick with low setting or do the readylift front and call it good.
95cobby
95cobby
Bowling Green, OH
Just to be clear my f150 4wd fronts are on the bottom ring.. you could go second ring but it was deff to high for what I wanted and the spring was too close to the a-arm for comfort.
I think 16plati is right on the 4600s.. there isn't another shock that will fit the rear of the Expy that I know of. Could maybe have someone make a shim/spacer that would go in between frame and top plate of the shock mount
