Bolt on upgrades for 17 XLT
miket961
Atlanta, GA
Hi All, what are some items I can upgrade on my XLT?
Examples: I have clothe seats but would prefer leather. If I upgrade, will the front seats wire up and work? Does the second row bench just bolt in? Can I install 3rd row and the motor or raise it up/down? I’ve seen info on older Expeditions having the wiring harnesses available to add the motor.
Can I install the BLISS mirrors?
Can I install the 8” display? I found a video of a company offering the upgrade kit but it’s out of my budget at $1800
Any others?
16plati
VA
Any others?
Convert all int/ext lights to LED.
Chop the rear resonator off, sounds much better without it.
Weathertech floor liners
Oil catch can (jlt performance $149) best investment I’ve made
Tuner
Black
Kentucky
Unless you get a killer deal on junkyard pull seats having someone install Katzkin leather will actually give you a better quality leather than factory and they can add heat. Will be cheaper than swapping.
M
miket961
Atlanta, GA
I was quoted 800 for front and third row at a local yard
I don’t think stock heated/cooled leather seats would hook up nor work. I used to have an XLT and now have an Eddie Bauer. My XLT had none of the switches, harnesses, modules that the Eddie Bauer seats have.
M
miket961
Atlanta, GA
Thanks. That’s what I’m worried about. I’m not sure what wiring harness is I’ll find when I open things up
Katzkin is good stuff, you can also add heat. Likely an easier option.
bobmbx
You can have your current seats re-upholstered in leather. Wiring isn't an issue that way.
Yes. If you install "same year" seats, the holes should already be there.
You may have to replace the entire rear floor area to do that.
I think you can put the mirrors with BLIS on, but it won't integrate with your dash or chimes.
The real decision maker is what version of Sync you have. Sync is not "bolt on".
M
miket961
Atlanta, GA
I have a 2017, is Sync the same for all this year? Or is there a way for me to check? At some point, I know the trim package has the 8” standard
Can I upgrade my computer to integrate BLIS?
Yea 3rd row power fold may be a headache- perhaps replacing the rear quarter plastic to have the button mount. The carpet. Add the motor and hope the harness is there...
M
miket961
Atlanta, GA
I know this isn't the answer you are looking for, but it would probably cost you less in the long run to sell your truck, and buy one with the options you want..
Thanks Scott. Nice to see you in here too.
Just got my first Expedition after my daily driver was totaled in May. Got a great deal on a certified pre owned. Just wanted to upgrade a few things if I could
Do you drive an Expedition as well?
