04WHITEEDDIE
Soft brake pedal sinking to floor on my '04 4x2 EB 4.6L with ~240K miles. I replaced the master cylinder (performed bench bleed before installing MC) and then bled all 4 calipers 2 times with pressure bleeder...nice clear fluid came out with no air bubbles at all calipers....no change to soft pedal. Hooked up the Autel scanner , no ABS codes. I also performed the ABS Auto bleed with the Autel and then bled the calipers again.... no change to soft pedal. I suspect there is internal fluid leak (bypassing) within the ABS hydraulic unit.
Ford no longer offers replacement ABS hydraulic pump for this vehicle. Does anyone know of someone that can repair these ABS hydraulic units? Aftermarket replacement? There is always the salvage yard , but I prefer to rebuild or replace it...I plan to keep driving beyond 300K. Appreciate any advice.
