bumper hitches
opie
Indiana
Bumper hitches? Do you trust them?
The bumper hitch is rated 4000lbs (400 lb tongue weight). A classIII hitch would only gain me 1000 lbs and 100 lbs for tongue weight. I'd be towing a trailer full of wood 12-15 times per year, and thats pretty much it.
The trailer belongs to a family member, and he estimates that it would weigh about 3000 to 3500 full of wood....And i have concidered taking it to the local truck stop the next time its full to have it weighed.
johnnystar
west coast canada
What is it on?
Bumper Hitches are not nearly as reliable as the easy hitch that bolts to your frame. Bumpers are held on by 2 brackets , usually 2 bolts per bracket and the weight displacment is fully on those. Thats why you see alot of bent warped or missing bumpers.
The others displace the weight over the whole rear end of your vehicle, so as long as your drivetrain can handle what your towing, you should be good to go!
AvroAero
Toronto, Ontario
Not worth it. If the trailer is to low or to high it'll resist latching, or prevent latching if its steep enough. If the trailer isn't generally level it'll cause you problems/headaches. Since your towing about once a month get the hitch. Plus if you go over an incline the bumper will hit the coupling and usually what causes it to bend.
That and everything Johnny said. Personally I wouldn't use it ever.
mustangrfast88
middletown oh
i just bought a class 3 /4 hitch it is a class 3 with a 6000 pound weight and a 10000 pound weight distribution hitch. for the 150 bucks for the hitch and the 100 bucks for the witring setup i am running. the 250 is alot better then 500 to replace the bumper
O
opie
Indiana
well, i'm going to go with the classIII hitch and forget about the bumper hitch.
But i did talk to my father in law about it (he's an engineer for chevy) and he said that if its rated at 4000 lbs , then its probably good for up to 5000 lbs as there is usually a 80%/20% safety factor figured in to the actual rating. Plus, if you look under the bumper, there is a steel plate that is bolted to the frame that the ball hitch is mounted to....
but, i've never trusted bumper hitches before, so why start now ....
johnnystar
west coast canada
Plus the versitilty of the hidden hitch is fabdabuluos.
You can change the hitch easy. regular hitch's, drop hitch's, bike racks, tow bars etc. Lots of goodies. Not too mention little plugs with boat props..there so cute.
Anyway, they are just a way better option. When i go out shopping i leave my big old drop hitch on, so people dont park right up on my bumper. (I hate that!)
mustangrfast88
middletown oh
i just installed mine today 8 bolts it was so easy a extra hand would of helped but i did it by myself. it is rated at 6000 pounds and 10000 pounds weight distrbutuions but there was a sticker on it that said 14000 with weight distrbution put a class 3 on your truck you will be much happier
AvroAero
Toronto, Ontario
Canceling out the safety factor puts it to a n unsafe/breaking point. Which I wouldn't want to be in. Besides, where do the safety chains go? Right to the frame?
O
opie
Indiana
no, there's a place made for the safety chains...and it is already set up to plug a wire harness in for lights.
johnnystar
west coast canada
The class 3 is the way to go, hands down. I dont think you'll find anyone that can argue that point. Thats why most high end Trucks/SUV's with great towing packages have them stock.
As i said the versitily itself is phenominal with regular hitchs, drop hitches,bike racks and many other accessories.
Safety chain slots are heavy duty. Surprisingly affordable from NAPA or LORDCO. Well worth the bucks. Theres all different weight classes too. Pretty much as light or as heavy duty as you can imagine.
ktrjones12
A rv bumper hitch can carry 3500lbs. maximum. It's tongue weight is 350lbs. for 4in. In fact, it proved to be sturdier than my bumper. The weight of the hitch, bike rack, and two bikes broke the weld that held the bumper on. Be sure to check with your trailer manuafacturer before installing anything on the bumper. Mine appeared to be strong enough but the leverage of the bike rack was too much for it....
Tracy
Australia
Since you are using bumper hitch ,you will be having more about its performance.If you are not happy with it better go for other hitch. Search in the internet and you will get to know about the right kind of hitch to be used for various purposes.
