Dustin Gebhardt
My ABS light has been showing up occasionally for the past several months. After doing the power and ground testing on the cable as I found elsewhere on the internet, I've decided to throw a new (used) pump at it. I don't have the replacement pump in-hand just yet, but I believe that I can leave the hydraulic portion connected to the brake lines and replace just the electrical side, if that is the problem. Does anybody have experience with this issue or error code? I don't mind replacing the hydraulic side if needed, and I believe that FORScan will allow me to activate the ABS pump to help purge any entrapped air bubbles.
