Can I fit 37's ?
reefkrazy
ct
I have a 3 inch body lift. cranked torsion bars. Lifted it by adjusting the airbag sensor up just a tad. Cut front valance for room. Im running 33's on stock 17's. I know I can go 305 70 r17 (35) but I don't think it would be enough......lol Thanks
TRTLSLO
Kalamazoo, MI
I ran 315/70/17's stock by just cutting the valance. I would think it possible for 37's with a body lift. Check with "babysilk" on this site. I'm pretty sure he is doing 37's with a torsion twist and a bodylift
reefkrazy
reefkrazy
ct
Thanks guys. I'm know that if I go with
35's im not going to be satisfied. Go big or go home right!
FordandPolaris
Saint Cloud, MN
Actually talk to Thermo (not to discredit Babysilk, but I think his only has 35's), I know he has 37's on only 4" of lift, he will be your best option for making it work. Good luck.
reefkrazy
reefkrazy
ct
Thanks. I saw babysilk is running 6" lift. Im somewhere between 3 and 5 inches. Prob closer to 5 with the airbags. I can always tweak it alittle more.
MUSKYMAN52
Illinois
How big is your torsion lift? i could only crank mine up 2", couldve sworn 3" was possible.
reefkrazy
reefkrazy
ct
I got 2 inches on torsion twist. It leveled the truck. I have air ride so there are airbag sensors that I can move up a little and it raises the truck. Here is a pic with just the torsion twist.....
Thermo
technical advisor
Reef, I sent you an e-mail. Like I said in the post, to run 37's like you are talking, you are going to need some very specific components to make it all work. You deviate even a little bit and you are asking for some major rubbing issues or damage to the tranny (too tall of a tire with not enough gear). Plan on spending about $4000 to do what I recommend. I did a lot of research and tons of measuring. Even then I had to do a little bit more modification than I was originally planning. Also keep in mind that this allows you to run the truck up to full twist and not have rubbing. If you are planning on just a street queen (which is not what I am getting the impression you have in mind), then you can relax what I say a little (very little) bit.
If you want to see pictures of what you are looking at, check out http://www.fordtruckworld.com and then do some looking through the galleries for "Thermo". There, you will see my detailed explanation of how to do the wheel well mod I talked about, cutting of the fender, and what the truck looks like all twisted up and how little room that is left over under the worst case conditions.
Not trying to steer you away, but there are some members around that have tried what I did and didn't have too good of luck. hate to see you spend big money not to get what you are after.
reefkrazy
reefkrazy
ct
Cool thermo thanks for the info. Im going to check it out.
MUSKYMAN52
Illinois
Shes looks nice, i got coil springs all around so im hopin my rear coils will continue to stretch so far they stretched 1" in the back.
Lane24
technical advisor
Alberta , Canada
I have the same set up as you, if you want to see what just 35's look like.... I haven't done any trimming whatsoever.... and it looks like there is room to spare. So with some minor mods, 37's might just stuff in there.
reefkrazy
reefkrazy
ct
Thanks lane24. I've seen your truck on here b4. Thats 35s with a 3inch body lift right. I like the way your truck looks :)
Lane24
technical advisor
Alberta , Canada
Yeah... 3 inch body lift, 2 inches from the torsion crank up front, and 2 inch coil spacers in the back.
reefkrazy
reefkrazy
ct
Thermo, I just checked out all your gallerys on that site. All I can say is wow! Thank you for all the info. I defently need to rethink my plans for know. I'm not up for changing gears at this point. Maybe 35's for now lol :)
MUSKYMAN52
Illinois
Nice, i got that stock 3.55, i heard its a good ratio for off road and mud but havent had a chance to try it
reefkrazy
reefkrazy
ct
It's a beast! I took it out on some crazy climbs over 40 degrees without 4x4 or awd. I was impressed.
