Mark Buckner
I am preparing to replace the OEM Radio/Nav unit in my 2012 EL Limited with a Kenwood head unit. I would very much like to use the existing GPS/SiriusXM antenna rather than adding a magnetic SiriusXM antenna and having an exposed wire snaking into the vehicle. I see that there is a splitter in the factory wiring to separate the GPS and SiriusXM functions of the antenna for SOME Expeditions but have had no luck verifying that my 2012 has such a splitter. I guess we will not be able to find out until my installer tears into it unless someone here knows about that.
I'm hoping someone who has replaced the OEM radio with an aftermarket radio (with built in Nav) can chime in and let me know how you solved this problem. I *AM* aware that I will need to buy a separate aftermarket SiriusXM receiver that will require an antenna. This is what I am hoping to connect to the OEM antenna.
I am less concerned about the GPS, as I understand that the GPS antenna does not need to be mounted on the outside of the vehicle, and can even be mounted under the dash.
Grateful for any assistance! Thank you!!
