can you make a 4awd go to 2wd.....
ExpeditionDrew
Omaha
i was wandering if there was a way to disengage the 4awd and just do 2wd, maybe put it on a seperate on/off switch....trying everything i can to save gas......i have a 99 4.6...cold air, and it averages 11.5mpg is that normal....
panda24619
San Diego
thats normal. thats about what i get. but you can. look up brown wire mod.
Rockunlimited2
Omaha
Or just pull the front drive shaft, It is common on jeeps to do this to reduce the wear on the gears when on the street, it also helps with mpg since it removes drivetrain drag. Check with other first thought, I am still learing about expeditions, my have other issues.
JeffS
Detroit
I have 98 XLT, 4.6L, and with the 2 wheel drive, its' gas mileage isn't any better than yours. I get about 10 mpg city, and 11 to 12 highway.
toms89
technical advisor
MD
You can pull fuse #104 to keep it from going into 4wd. But as the others said it will do nothing for your gas milage. In A4wd it only goes into 4wd when it senses wheel slip (rare). Its not all wheel drive... it automatic 4 wheel drive.
