CEL goes off without fixing the problem?
AuctionExp
Beaverton, OR
So I've got a '97 Ford Expedition (5.4L EB, 4wd) and the check engine light has been on because of a bad cat converter for quite a bit, and then just yesterday it turns itself off?
I shut off and re-started the vehicle to make sure the check engine bulb was not burnt out (it was not).
Has anyone else had this happen to them? I'm going to connect and pull codes tonight and will post if anything is present.
B
bedrck46
Get the codes and post them will be able to provide better answers rather then making guesses at this point
IMINYOURCHAIR
Altoona Alabama
It could possibly be that the cats are not totally gone and the parameters were right for the light to go out. It still may have reduced performance but the code was allowed to expire
Snapshot
Kentucky
I agree with the previous post, I'm had a similar issue before. My expy started to slightly misfire once on the interstate when I was heading home. I was only a few miles from the exit so I drove it home. The CEL stayed on the entire time I was driving. I turned it off and back on and no light even though it blinked while coming on. I had to drive it about 30 miles with it running like crap for it to come back on so I could get a code pulled. I wish you the best of luck!
FordandPolaris
Saint Cloud, MN
I'm guessing conditions were just right and the downstream o2 got a good reading for once. See if it stays off when the weather changes. The computer stores the codes even after the light goes out so unless you unplugged the battery, they should still be there.
AuctionExp
AuctionExp
Beaverton, OR
So much for no CEL. It's back on. Code that is present is P0430, cat efficiency, Bank 2 (is Bank 2 the driver or passenger side?)
kyle_in_rure
TN
Mine shut off about a day after I had some pretty serious misfires (CEL flashing its ass off and engine running terribly). I think if it goes so long without error the computer resets itself.
The problem may not go away it just doesn't detect anything.
hendricksen11
Wallops Island, VA
Oh
My mechanic told me 1357 were passenger side and 2468 were drivers.. good to know, and now knowing that, that means he didn't replace the right coil pack, but at least all the plugs were changed..
hendricksen11
Wallops Island, VA
I think I would look for a different mechanic
Yeah. He was the mechanic at dealership where we got Expedition from.. did a good job with spark plugs tho, they were originals in my 05 and had a 135k so I was apprehensive, but he had the removal tool and got all 8 done in two hours
