Changes in the 4wd system on new Expedition
michguy
michigan
I have had three Expeditions (98,04, and my current 08). So I am used to the 2H, 4A, 4H and 4L set up. But the new Expeditions (for the first time) now have single range rather than high-low range transfer cases. So now you have just 2H (2wd) and 4A (4 auto) settings unless you elect either the FX4 off road package or the Heavy duty trailer tow package, in which case you get a two speed transfer case adding a 4L setting and, in addition, a 3.73 electric limited slip differential. There is no longer a 4H setting regardless of how the Expedition is configured.
So I have a couple of questions to hopefully some that have used their new 2018's in the snow or off road. In the past I have used 4A for normal road use when road conditions are questionable, as they often are in Michigan. If the snow is heavy or I am on one of our trail roads at deer camp I have used the 4H setting. I admit to essentially never using 4L.
First question: Is the loss of the 4H mode significant, or do the new terrain settings adequately substitute? Second question: For those that have either of the two packages mentioned above, does the limited slip differential really do anything that the old system failed to do? And does the lower axle set up (3.73 vs 3.3) significantly impact vehicle gas milage. If so, by how much? I believe that the F150's continue to use a two speed set up essentially the same as in previous Expeditions, which makes me wonder if the set up in the new Expedition is as "robust" as that used previously.
Eventually I would hope to place an order. However, I have attempted to get technical answers to these questions from Ford, but no one has been able to answer or get me connected to anyone with the appropriate knowledge base, which is incidentally, very frustrating for long time Ford customer. Any help would be kindly appreciated.
shane_th_ee
Seattle
For a 4H only user, you’ll never see a difference if you lose the 4L. 4L is useful for rock crawling and very slowly descending steep and slippery slopes as engine baking will keep the truck moving very slowly without the driver needing to touch the brakes. The locking limited slip rear differential means you’ll never get stuck trying to start if opposing corners don’t have traction. Does your existing Expedition have the limited slip rear differential? If it doesn’t and you’ve never had an issue with it, you’ll be fine with the open differential. The other thing you’d lose going to the “4A” only four wheel drive system is the “neutral” mode which lets you tow it without a dolly. I just ordered an FX4 this past week, so I can’t comment on the gas mileage difference between the two rear axles.
deweysmith
Montreal, QC
In my 2012's manual, 4H says it splits the torque 50/50 between the front and rear in 4H under MOST conditions. It still has the freedom to shift it back and forth as necessary, the difference being between 4A and 4H is that you'll get driveline windup/binding when cornering if you're in 4H on dry pavement.
4A is fantastic for most usage. I thought it would light up the traction control light when it was shifting power around, but it doesn't. It will shift power between the axles as needed and probably before you even notice the rear axle slipping. I tried it out a few weeks ago at the Utah sand dunes. It would slip, but eventually get going in 2H, but in 4A it could get going on sand with very little throwing of sand before it applied power to the front wheels to. Pretty awesome.
I don't have a 2018 but I bet the terrain selection system allows it to preselect a torque split value optimal for most conditions you give it, but it will still adjust the split as needed.
Meeker
Calgary, AB, Canada
I'm about to order a 2018 XLT, and I have a question for you guys. Is there any difference in the 4x4 system if you choose the FX4 package or the Heavy Duty Trailer Towing package? Do you get the same terrain options in the dial menu?
I believe you can select the 3.73 Limited Slip rear axle as a standalone option with the HDTT package. Do you then end up with the same drivetrain as FX4? Obviously the other FX4 stuff would be missing (skid plates, shocks, radiator).
Hey, why wouldn't you want the bigger radiator with the trailer towing package anyway? Inquiring mind wants to know.
shane_th_ee
Seattle
The upgraded center differential (really a transfer case), the 3.73 rear axle and the heavy duty radiator are all included in BOTH the FX4 package and the Heavy Duty Trailer Tow package. What you're really choosing between those packages is skid plates, shocks and trim items (wheels, running boards, etc) OR integrated trailer brake controller and the pro trailer backup assist. Note further that the trailer brake controller can be added as a $495 (US) dealer installed option. Finally, if you do want it all, you can get the FX4 package and the max trailer tow package price drops to $1100 (US) since it only includes the trailer brake controller and the pro trailer backup assist...
shane_th_ee
Seattle
And here I thought our 41’ rig (Expedition Max + travel trailer) was long...
Bayoudude
Baton Rouge, La
correction the 4A equipped vehicles are towable 4 down, and have a procedure to put the transfer case into neutral
https://www.fleet.ford.com/resource...ngguides/Ford_Linc_18RVTTowGuide_r2_Nov27.pdf
page 13
Looking at the owners manual, it says the only way to tow 4 down is with one equipped with 4L.
I tow a Jeep Wrangler now but want to have the option to take the Expedition if I needed it for a trip. I've been researching this vehicle to replace my F150.
powerboatr
North East Texas
yep there is some confusion about 4l, it is most likely that the single speed transfer cases are not equipped with the neutral feature.
but if you look at the 4x4s on the expy only a very small percent will be the single speed because if you get the hd tow package or fx4 then the 2 spd is in there. imo, i wouldnt have a 4x4 without the hd tow package. i have heard many sales guys in the past, even with super duties being very cocksure about 4l and pulling boat from water. we had 250 and 350 and used 4l every-time we pulled our boat out. But ours was not light nor small and florida ramps tend to be slick with sea grass. so it was nice to idle out of the water
edizzle
Cashiers
can a transfer case vary the amount of split between the front and rear? i didnt think so. i know a center differential can, but thought a transfer case was a purely mechanical predetermined amount of split.
I am very mechanically inclined and have above average understanding of vehicles, but there is so much different information regarding the 4wd system on the expedition and how the drive modes effect this.
My Explorer has a center differential or PTU that is totally variable as to how it splits power between the front and rear. The advance trak, in my understanding, controlled all of this with wheel sensors and braking to send power to wheels that have traction. for almost any normal muddy, gravelly, snowy road, it worked wonderfully!!!! obviously the avid off-roader would not be satisfied, but it wasnt really marketed for that.
just trying to find some definitive information on the behavior of the 4wd system to understand and know how to use it. we live in the mountains and frequently need 4wd/awd systems to simply get to and from home!!!
deweysmith
Montreal, QC
Expedition has ControlTrac. It's not a center differential, nor a transfer case. It mimics a differential, but it's actually all electronically-controlled clutch packs.
The transfer case on the Expedition is just a gearbox that is either 1:1 or 2.64:1 depending on the mode, normal or low (used in 4L.)
Explorer used to have ControlTrac, and then ControlTrac II, which was based on a viscous coupling. Ford has since scrapped that in favor of Intelligent 4WD which works mostly like ControlTrac except it favors the front wheels instead of the rear.
powerboatr
North East Texas
You're a "go big or go home" sort of a guy, aren't you?
well, in a word YES. we liked to be able to go out of sight of land in the Gulf and Atlantic.
haven't seen anything concrete on the terrain management system on the new expy, as far as tq split available to front wheels under some conditions. 4h or 4A was 50 /50 . but now i could see any degree of split based on wheel slip or terrain loads, if the 18 systems are different from previous editions, but i suspect the transfer case is not to different and the vehicles uses electronics and braking to force tq to other wheels
we use 4A all the time, our roads suck and get slick or loose with no notice. since its as close to AWD i could get in the expy, its what we live with.
deweysmith
Montreal, QC
4A has always been capable of 100/0 and is usually 0/100 (full RWD) unless wheel slip is occurring or predicted. It's capable of detecting and reacting to wheel slip within 1/3 a wheel revolution, and even predicting it under certain conditions.
4H would lock it to 50/50, yes.
