Changing Plugs/COPs
FordGate
Damascus, MD
I finally bit the bullet and did the plugs on the 2003 EB with 5.4. Not as bad as I thought or read. The only really bad one is the passenger side rear and that wasn't a total PITA. All you need it one universal joint and a few extensions. I replaced all 8 plugs and COPs in well under 2 hours. I didn't worry at all about breaking the existing plugs and none broke. The old plugs had 130k miles on them and were worn the -f- out. Wow I am surprised the car ran at all! The good news is all 8 plugs looks really good accept for the electrodes being burned almost gone. The gap was at least 3x bigger than specs too. I had at least 3 failed COPs. Runs like a champ now and I expect better mileage as well.
Oh and I used plenty of anti-seize on the plug threads as well as around the boot for the COP. I also put dielectric grease on the ends of all the springs.
This isn't too bad a job and anyone handy can do it.
mwhyes
Arlington VA
Thank you for the note - I plan on doing this myself within the next week or to. I'm at 126k. Did you have to remove anything other than the air intake?
F
FordGate
Damascus, MD
Just the air intake, the engine cover, and there is something that blocks the front driver's side plug that is easy to remove not sure what it is.
You need a 7mm socket with extensions and a 7mm open end wrench to remove the COP bolts. One of the COP plugs is hard to get to without the wrench the fuel rail is right in the way of a longer extension. The other 7 are ok with just the socket. Maybe if you had a small universal joint or a socket with built-in swivel you could get it with a socket. You also need a 7/16" for the air intake along with a screwdriver. Also get dielectric grease and anti-seize.
Also I used 2 spark plug sockets. One with the rubber plug for removing the spark plugs and one without for putting them back in. My problem using the rubber plug for putting them back is when I went to remove the socket, it was too tight on the plug and the extension pulled out. So I just carefully dropped the sparkplug in the hole and used the non-rubber plug socket to put it back in. If you had a tighter extension you wouldn't need that.
Good luck!
PS My hood struts slowly sag and the hood shuts when it has been opened too long. I used a piece of wood to keep the hood wedged open. Keep this in mind you don't want the hood slamming on you while you are bent in the engine.
mwhyes
Arlington VA
Cool, thanks. I did pick up a 7mm u-joint socket from Amazon a few weeks ago in anticipation of the work, so I hope that will be helpful. Thanks again.
mwhyes
Arlington VA
Just completed. Took 4 hours - it was hot and humid in DC these last few days, so a lot of sweating and rest breaks. It wouldn't have kicked my butt so hard if it were cooler out. It's an intuitive job, but just hard to wiggle around in there. If every cylinder was like #1, it would take less than an hour. Most of the time was spent removing the COP bolts and lining up the plugs (esp #3/4).
The only downside was the hose connecting the PCV valve and the throttle body was severed while I was fishing around (probably was rotten), so I ordered a replacement. I have duck tape holding it as a bush fix until the part arrives.
Strangely - it started up but ran hard for a few minutes. I shut it off, checked for codes (thinking maybe one of the packs wasn't fully secured to the plug) which there were none. I restarted after 10 minutes and was instantly back to normal and runs very sweet. Drove 20 miles without issue/no codes. May be some rotting vacuum tubes (which will be replaced) or just dirt/sweat that needed to clear out of the bores. Not sure.
Sherman
Arkansas
Just wondering what did you torque the spark plugs too?
WarrenG
Everett WA
What brand of COPs did you use and where and how much did they cost you?
thenaaks
Sparta TN
The rough running was probably water or oil running down the spark plug hole once you pulled the plug out. I've changed lots of plugs and coils in 4.6 and 5.4 engines. Almost all of them had water in a plug hole or two.
I recently changed my own plugs while removing the intake manifold to replace gaskets. I had the worst time getting the coil boots out. Only one coil came out with the boot attached. All the others had to be pulled out with pliers. Several were ripped into 2 or three pieces. Two plugs had to be removed with part of the boot still stuck to the plug. Had to pound a standard deep well socket over the boot onto the plug. Moral of the story, use plenty of silicone grease when installing new plugs
As far as coils go, I ordered a set of 8 on amazon for $50. I've installed six of them in friends' cars over the last 3 or 4 years. So far, so good.
igozumn
near Kansas City
... I didn't worry at all about breaking the existing plugs and none broke.
While anything can happen, they didn't start having plug seizing/breaking issues until the 3-valve was introduced in the Expedition in '05 and the F150 in '04.
Torque spec from the shop manual for the plugs is 15 ft/lbs (20Nm) on an 03 Expedition.
I too, had the first one grab the plug holding boot in the socket. After the first one, I just didn't push the plug all the way into the socket. Just enough to hold it and also made sure I didn't push down on the wrench while tightening. Had the same issue when I put my Town Car back together.
I did my plugs and coils when I had the intake off for gasket replacement. No issues with bad coils or plugs, but decided to be preventative and hopefully not have to change one out on the side of the interstate during a heat wave.
mwhyes
Arlington VA
I surprisingly had no issues with plugs or packs - they all came out relatively easily (5.4l 2v).
This is correct. I actually went up a hair to 18 as these plugs are known to walk out of their threads.
The yellow Accel 140032 ones from Amazon, approximately $150 for 8. Motorcraft SP-479 plugs, though ($10-15 for all 8 I believe)
F
FordGate
Damascus, MD
I didn't care at all about torque. I just tightened them down. I've replaced hundreds of plugs and never torqued any of them. Useless waste of time IMO!
rice_classic
Home
It seems one of the primary causes of the plugs walking out is this:
Oh and I used plenty of anti-seize on the plug threads .
The Motorcraft plugs are nickle plated and instructions specifically mention to NOT to use anti-seize on them.
When I bought mine it was running on 7.5 cylinders because one of the plugs backed out a bit, the previous owner had NGK plugs installed with.. you guessed it... lots of anti-seize. I went back to MC plugs because I've found that Fords tend to work best with MC parts.
mwhyes
Arlington VA
Ah. I didn't catch these instructions. I don't plan on diving back in to the engine to do the job again, so unless any issues pop up....is what it is.
F
FordGate
Damascus, MD
Don't lose sleep over this, I very seriously doubt the plugs will back out because anti-seize was used.
BTW: I used Bosch plugs. Not sure what they are made of.
