Changing Rims size
z168
Cali
I have an XLT 2WD with 255/70R16 rims. I plan to switch to 18x9.5 rims and was suggested I get 285/60R18.
However my stock tire diameter is 30" while the new tires will be 31.50".
my question is, should I get 285/55R18s instead to keep the factory diameter? Or am I making such a big fuss about it?
tonydiv
technical advisor
Middle River, MD
If you like that low sidewall thing, then the 55s would look cooler. Your speedo could show a mile or two slower than you're actually going, but that could be changed with most of the programmers out there. I doubt that you'll notice any performance difference with the slightly bigger rubber.
Z
z168
Cali
as far as the looks department, I do prefer the bigger one. But going 55series would keep the factory diameter and keep the speedo accurate
where can I re-calibrate speedometers?
