2023 timberline 4th gen .Does anyone know why I am getting this message. I did check the output of alternator and it’s at 14.4 volts. Then tested my battery with a fox battery tester and the battery tester reads the battery is good. The tester readings of battery is 559cca. The battery is an agm 760 cca and battery tester says it’s good. Then ran tester for starting and charging tests. All came back good. Battery is 2 1/2 year old as we got this new in may 2023. Does the diagnosis to trigger light on screen when the battery gets below a certain cca. Car starts fine and runs good. There is no gauge reading voltage so I can’t monitor it when I’m driving to see if it’s having an intermittent voltage loss. Already made an appointment with dealer but they can’t look at it for another week .
