"Check fuel cap" indicator in the instrument panel
outdoorguy
Utah
My "check fuel cap" indicator light keeps coming on in the instrument panel. Any suggestions as to why this is coming on? I check the fuel cap and it is on and in the correct position.
Quasar
Milwaukee, WI
Most likely the seal is bad on the cap itself. Id start cheap and simple and replace the gas cap.
O
outdoorguy
Utah
Thanks Tom, I will do that, I did consider that also, haven't done it yet, but was curious as to if this a common problem with the Expeditions and if so, all the potential problems that it could be, Thank you for your input. :happy107:
Skauber
Cagayan de Oro, Philippines
There's no physical switch that checks if the fuel cap is on or not. The evap system is probably detecting a leak and thinks it may be a loose fuel cap. Replace it with a new one first, if that doesn't fix it you'll have to diagnose the evap system and check for leaks or loose hoses. Most common on these I believe is the solenoid.
Newport News, VA
yes this is common becuz of the constant use of the cap...ur throwing codes so its not getting a good seal...
Ed_Strong
SWFL
where's the location for this solenoid? how do I diagnose it? Do you have a picture or the part number on a 2003 XLT 4.6L?
smasmasemsem78
Hello I bought a Ford Expedition and after he left a short sound of the engine differed annoying voice and not be afraid cycle engine with ignition engine light on the dash went to a specialist p0349 + p0340 + p0345 said must be the engine change with the knowledge that you drive on a very good Highway I hope to find out why and Thanks
أرسلت بواسطة iPhone بإستخدام Tapatalk
