www.crutchfield.com
A double DIN radio will fit with some trimming of internal dash plastic (unless that Clarion is already a double DIN). If you buy from Crutchfield, you'll get all the needed adapters and instructions for trimming the dash.
His clarion is single din, but the Ford one is about 2 1/2 to 3 inches thicker I don't think the Mach and standard Ford units are plug and play. Theirs probably a way to make it work. But all he has to do is look at his front door speaker grills. Mine says Mach right on them. I believe the Mach setup uses a pre- amp only head unit, that gets power to the speakers via the amps. The non Mach has a built in amp in the head unit, at least it should. From what I've read in the past, I believe that is an accurate assessment. I haven't dug into mine, so if I'm incorrect, please let me know.
Just read up on the difference. Premium system is driven by the built in amplifier of the head unit in the dash. It has the lower power amp that's built into it. You also don't have the 8 inch subwoofer or its amplifier in the passenger rear. The cd changer, and cassette radio head unit are similar, but the wiring is different. You can go with a factory unit online, maybe Ebay, or one of our members has one. If you go oem make sure it's not the Mach stereo, but the premium one.
Well apparently the units that are being sold on EBay don't know to state the most simple information. They have oem part numbers, but don't say if their Mach or premium. Best advice, go by your local Ford dealer, get the part number that matched your vin number. That way you can match the radio. They leave the info too vague. Theirs probably only 2 available that year, your model and mine the Mach setup. Anyway do a little homework, and find the right one. They even have a website that sells an original with a 3.5 mm plug to go to your I phone. Wish mine had that, might have to order one. Go on Ebay, you'll see em all.
