code problems 340/345
krice5
Indiana
Have an 06 expedition we bought new has 117,000 now took it in for cam phasers and ended up having the 5.4 triton 3v completely rebuit got it back drove a few hundred miles and it started sounding like the cam phasers again however you can clear the codes and it runs good at an idle drop it in drive at it starts all over again if you rev it in park sometimes it smoothes out or if you clear the codes it will start and idle good again did this for like 3 hours cold or warm does the same thing anyone had similar issues? any expert advise wood be great the shop is now telling me they think its electrical
Bedrck47
Elizebethtown, PA
P0340 - Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
Description:
The test fails when the powertrain control module (PCM) can no longer detect the signal from the camshaft position (CMP) sensor on bank 1.
Possible Causes: CMP circuit open
CMP circuit short to GND
CMP circuit short to voltage
SIG RTN open (VR sensor)
CMP GND open (Hall-effect sensor)
CMP circuit short to CMP2 circuit (if equipped)
CMP incorrectly installed (Hall-effect sensor)
Damaged CMP sensor shielding
Damaged CMP sensor
Damaged PCM
P0345 -
Camshaft Position Sensor A Circuit (Bank 2)
Description:
The test fails when the powertrain control module (PCM) can no longer detect the signal from the camshaft position (CMP) sensor on bank 2.
Possible Causes: See the possible causes for DTC P0340.
Temple, Georgia
If Indiana salts the roads during the winter months, I'd have a real close look at the wiring harness and connectors.
