P0010 Intake camshaft position actuator circuit open (bank 1)
P0011 “A” Camshaft position - timing - over-advanced (bank 1)
P0012 “A” Camshaft position - timing over-retarded (bank 1)
P0102 Mass Airflow (MAF) sensor circuit low input
P0103 Mass Airflow (MAF) sensor circuit high input
P0112 Intake Air Temperature (IAT) sensor circuit low input
P0113 Intake Air Temperature (IAT) sensor circuit high input
P0117 Electronic Coolant Temperature (ECT) sensor circuit low input
P0118 Electronic Coolant Temperature (ECT) sensor circuit high input
P0020 Intake camshaft position actuator circuit open (bank 2)
P0021 Intake camshaft position timing - over-advanced (bank 2)
P0022 Intake camshaft position timing - over-retarded (bank 2)
P0040 Upstream oxygen sensors swapped from bank to bank (HO2S - bank 1, sensor 1/bank 2, sensor 1)
P0041 Downstream oxygen sensors swapped from bank to bank (HO2S - bank 1, sensor 2/bank 2, sensor 2)
P0068 Throttle position (TP) sensor inconsistent with mass air flow (MAF) sensor
P0102 Mass air flow or volume air flow circuit, low input
P0103 Mass air flow or volume air flow circuit, high input
P0106 Manifold absolute pressure or barometric pressure circuit, range or performance problem
P0107 Manifold absolute pressure or barometric pressure circuit, low input
P0108 Manifold absolute pressure or barometric pressure circuit, high input
P0109 Manifold absolute pressure or barometric pressure circuit, Intermittent
P0112 Intake air temperature circuit, low input
P0113 Intake air temperature circuit, high input
P0116 Engine coolant temperature circuit range/performance problem
P0117 Engine coolant temperature circuit, low input
P0118 Engine coolant temperature circuit, high input
P0121 In range Throttle Position Sensor (TPS) fault
P0122 Throttle Position Sensor (TPS) circuit low input
P0123 Throttle Position Sensor (TPS) circuit high input
P0124 Throttle position or pedal position sensor/switch circuit, intermittent
P0125 Insufficient coolant temperature for closed loop fuel control
P0128 Coolant thermostat (coolant temperature below thermostat regulating temperature)
P0131 Upstream heated O2 sensor circuit low voltage (Bank 1)
P0132 O2 sensor circuit, high voltage ( bank 1, sensor 1)
P0133 Upstream heated O2 sensor circuit slow response (Bank 1)
P0135 Upstream heated O2 sensor heater circuit fault (Bank 1)
P0136 Downstream heated O2 sensor fault (Bank 1)
P0138 O2 sensor circuit, high voltage (bank 1, sensor 2)
P0141 O2 sensor heater circuit malfunction (bank 1, sensor 2)
P0148 Fuel delivery error
P0151 O2 sensor circuit, low voltage (bank 2, sensor 1)
P0152 O2 sensor circuit, high voltage (bank 2, sensor 1)
P0153 O2 sensor circuit, slow response (bank 2, sensor 1)
P0155 O2 sensor heater circuit malfunction (bank 2, sensor 1)
P0156 O2 sensor circuit malfunction (bank 2, sensor 2)
P0158 O2 sensor circuit, high voltage (bank 2, sensor 2)
P0161 O2 sensor heater circuit malfunction (bank 2, sensor 2)
P0171 System Adaptive fuel too lean (Bank 1)
P0172 System Adaptive fuel too rich (Bank 1)
P0174 System Adaptive fuel too lean (Bank 2)
P0175 System Adaptive fuel too rich (Bank 2)
P0180 Fuel temperature sensor A circuit malfunction
P0181 Fuel temperature sensor A circuit, range or performance problem
P0183 Fuel temperature sensor A circuit, high input
P0190 Fuel rail pressure sensor circuit malfunction
P0191 Injector Pressure sensor system performance
P0192 Injector Pressure sensor circuit low input
P0193 Injector Pressure sensor circuit high input
P0196 Fuel rail pressure sensor circuit, range or performance problem
P0197 Fuel rail pressure sensor circuit, low input
P0198 Fuel rail pressure sensor circuit, high input
P0201 Injector circuit malfunction - cylinder no. 1
P0202 Injector circuit malfunction - cylinder no. 2
P0203 Injector circuit malfunction - cylinder no. 3
P0204 Injector circuit malfunction - cylinder no. 4
P0205 Injector circuit malfunction - cylinder no. 5
P0206 Injector circuit malfunction - cylinder no. 6
P0207 Injector circuit malfunction - cylinder no. 7
P0208 Injector circuit malfunction - cylinder no. 8
P0217 Engine coolant overtemperature condition
P0218 Transmission overheating condition
P0219 Engine overspeed condition
P0221 Throttle position or pedal position sensor/switch B, range or performance problem
P0222 Throttle position or pedal position sensor/switch B circuit, low input
P0223 Throttle position or pedal position sensor/switch B circuit, high input
P0224 Throttle position or pedal position sensor/switch B circuit, intermittent
P0230 Fuel pump primary circuit malfunction
P0231 Fuel pump secondary circuit, low
P0232 Fuel pump secondary circuit, high
P0297 Vehicle over-speed condition
P0298 Engine oil over temperature
P0300 Random/multiple cylinder misfire detected
P0301 Cylinder no. 1 misfire detected
P0302 Cylinder no. 2 misfire detected
P0303 Cylinder no. 3 misfire detected
P0304 Cylinder no. 4 misfire detected
P0305 Cylinder no. 5 misfire detected
P0306 Cylinder no. 6 misfire detected
P0307 Cylinder no. 7 misfire detected
P0308 Cylinder no. 8 misfire detected
P0315 Crankshaft position system - variation not learned
P0316 Misfire detected during startup - first 1000 revolutions
P0325 Knock sensor circuit fault
P0326 Knock sensor circuit performance
P0330 Knock sensor no. 2 circuit malfunction (bank 2)
P0331 Knock sensor no. 2 circuit, range or performance problem (bank 2)
P0340 Camshaft position sensor “A”, circuit malfunction (bank 1)
P0345 Camshaft position sensor “A”, circuit malfunction (bank 2)
P0350 Ignition coil primary or secondary circuit malfunction
P0351 Ignition coil no. 1 primary circuit fault
P0352 Ignition coil no. 2 primary circuit fault
P0353 Ignition coil no. 3 primary circuit fault
P0354 Ignition coil no. 4 primary circuit fault
P0355 Ignition coil no. 5 primary circuit fault
P0356 Ignition coil no. 6 primary circuit fault
P0357 Ignition coil no. 7 primary circuit fault
P0358 Ignition coil no. 8 primary circuit fault
P0400 EGR flow fault
P0401 EGR insufficient flow detected
P0402 EGR excessive flow detected
P0403 Exhaust gas recirculation circuit malfunction
P0405 Exhaust gas recirculation valve position sensor A circuit low
P0406 Exhaust gas recirculation valve position sensor A circuit high
P0411 Secondary air injection system, incorrect flow detected
P0412 Secondary air injection system switching valve A, circuit malfunction
P0420 Catalyst system efficiency below threshold (Bank 1)
P0421 Catalyst system efficiency below threshold (Bank 1)
P0430 Catalyst system efficiency below threshold (Bank 2)
P0431 Catalyst system efficiency below threshold (Bank 2)
P0442 EVAP small leak detected
P0443 EVAP VMV circuit fault
P0446 Evaporative emission control system, vent control circuit malfunction
P0451 Evaporative emission control system, pressure sensor range or performance problem
P0452 EVAP fuel tank pressure sensor low input
P0453 EVAP fuel tank pressure sensor high input
P0455 Evaporative emission (EVAP) control system leak detected (no purge flow or large leak)
P0456 Evaporative emission (EVAP) control system leak detected (very small leak)
P0457 Evaporative emission control system leak detected (fuel cap loose/off)
P0460 Fuel level sensor circuit malfunction
P0461 Fuel level sensor circuit, range or performance problem
P0462 Fuel level sensor circuit, low input
P0463 Fuel level sensor circuit, high input
P0480 Cooling fan no. 1, control circuit malfunction
P0481 Cooling fan no. 2, control circuit malfunction
P0482 Cooling fan no. 3, control circuit malfunction
P0500 VSS fault
P0501 Vehicle speed sensor, range or performance problem
P0503 Vehicle speed sensor circuit, Intermittent, erratic or high input
P0505 IAC valve system fault
P0506 Idle control system, rpm lower than expected
P0507 Idle control system, rpm higher than expected
P0511 Idle air control (IAC) system - circuit malfunction
P0512 Starter request circuit
P0528 Fan speed sensor - no signal
P0532 A/C Refrigerant Pressure Sensor A - circuit low
P0533 A/C Refrigerant Pressure Sensor A - circuit high
P0534 A/C refrigerant charge loss
P0537 A/C evaporator temperature sensor - circuit low
P0538 A/C evaporator temperature sensor - circuit high
P0552 Power steering pressure sensor circuit, low input
P0553 Power steering pressure sensor circuit, high input
P0562 System voltage low
P0563 System voltage high
P0579 Cruise control multi-function input A - circuit range/performance problem
P0581 Cruise control multi-function input A - circuit high
P0602 Control module, programming error
P0603 PCM Keep Alive Memory test error
P0605 PCM Read Only Memory test error
P0606 PCM processor fault
P0620 Alternator control circuit malfunction
P0622 Alternator lamp F - control circuit malfunction
P0625 Alternator field terminal - circuit low
P0626 Alternator field terminal - circuit high
P0645 A/C clutch relay control circuit
P065B Alternator control - circuit range/performance problem
P0660 Intake manifold tuning valve control circuit (bank 1)
P0703 Torque converter/brake switch B, circuit malfunction
P0704 Clutch switch input circuit malfunction
P0705 Transmission range sensor, circuit malfunction (PRNDL input)
P0707 Transmission range sensor circuit, low input
P0708 Transmission range sensor circuit, high input
P1260 Theft detected, vehicle immobilized
P1285 Cylinder head overtemperature condition
P1299 Cylinder head overtemperature protection active
P1464 A/C demand out of self-test range
P1572 Brake Pedal Position (BPP) switch circuit
P1602 Immobilizer/ECM communication error
P1622 Immobilizer ID does not match
P1639 Vehicle ID block corrupted - not programmed
P1703 Brake switch out of self-test range
P0500 VSS fault
