supahcraig
Hi y'all, first post here, I'm a regular on several jeep forums, which doesn't really apply here but now I've fulfilled my responsibility as a Jeep owner. I normally do all my own work, but I haven't had to dive into this car so I don't have my usual list of go-to places for basic info.
Had some weird stuff happening lately. temp gauge kinda jumps around, A/C sometimes stops blowing cold, steering makes a weird noise at full lock. Some of that probably points to a serpentine belt in need of replacement, that much is easy.
Related to that appears to be the belt tensioner. It seems to periodically move up/down, which may be related to the a/c compressor? IDK, my jeep doesn't have this "feature" and it doesn't really jive with my understanding of belt tensioners...or maybe it's gone bad?
But I'm also losing coolant. There are no visible leaks, and there doesn't appear to be any coolant in my oil. The old girl has 110k miles on her, so I'm probably due to change a lot of things, but I didn't know if there are some common weak points in the cooling system at this point. I've added coolant to the overflow reservoir twice in the last 4ish months, and I was able to add about half a gallon directly to the radiator this morning which seems like an indication of trouble elsewhere.
