Could Torque Convertor issue really be the GEM unit?
98EXPY 5-0
PA
I bought my 98 Expedition at the end of 2009. I drove it for two months and only had two instances of what I had determined to be torque convertor shudder. I determined that from what I read online. Then I needed a bunch of work for inspection, and being broke at the time, I let it sit at my friend's house for almost a year (extra vehicle anyway). Now it's inspected and the shudder is horendous. I basically drive it in 2nd gear unless I need to go over 50, then I use DRIVE and turn the OD off.
I couldn't figure out how sitting for 8 or 9 months would cause the condition to get so much worse.
So I was thinking, instead of being a Torque convertor issue, I am wondering if it could be something else. Since it got 10 times worse, while just sitting behind my friend's garage for a year.
When I first got the Expedition, the first time I drove it in the rain, I had all sorts of weird things going on. Lights and clicking under the dash when the key was off. Thats when I found the windshield leak, and learned about the GEM unit and fuse panel issues associated with it.
The leak is sealed now, as far as I can tell. But could there be damage to my GEM or Fuse panel that would cause my tourque convertor like shuttering issues? Perhaps a dirty corroded contact that doesn't let the lock-up solenoid engage or something?
Another issue I am having is that my check engine light sometimes comes on for a while but goes out. Sometimes it flashes and sometimes it's steady, but once I come to a stop, it goes away. The guys at the parts store said they can't scan it unless it is on when they do it.
Racenut
Deming, New Mexico
As far as the Tq converter issue I have seen stranger so I would not rule it out just yet.
But then you mention having the CEL flashing at you at times. When the CEL is flashing, it means that you have a missfire on one or more cylinders but it is random and not steady enough to SET the CEL. The best thing for that is if you have a buddy with a scanner barrow it ( or pick up a cheap one ) and keep it plugged in the truck while driving, once the CEL starts flashing hit the scan button and see what it is reading.
All of your issues could actually be spark related ( including the shudder ) I would order all new coils off ebay from seller id UNEEKSUPPLY ($90 shipped for all 8 and they work great many people on here and also F150online use them) and then change out your plugs with MOTOCRAFT plugs.
These coils are famouse for going bad at +/- 100,000 miles or if they get wet!
98EXPY 5-0
PA
Could the coils really cause the shudder? It runs fine through 1st and 2nd gear, then in 3rd gear I have to be above 2k RPMs or it bucks and vibrates like hell until I get it that high.
99 Expy
Laramie, WY
I am not 100% sure, but I think my uncles F150 had the similar problem like that and his coils were going bad, so its a possibility.
Racenut
Deming, New Mexico
Under acceleration is when you need the most spark and if the coils are going out ( something is causing a missfire we know this by the blinking CEL) you will not have the power needed and the truck will begin to shudder, buck and jump around.
Think of it this way what happens when you are driving a little 4cyl 5 speed car and accidently try to take off in 2nd instead of 1st! Or if you go from 1st to 3rd with out running the rpm's way up, it will jump, and buck all over the place until the motor recovers or until you grab a lower gear.
same applies to the expy 1st and 2nd are ok due to the lower gear ratio's, but once you hit third and that higher gear ratio the motor has to work harder to get up to speed. So if you have week spark then it will run like crap and that is when you will see the blinking CEL for the missfire which will then give you that shudder feeling until the rpm's are high enough to smooth out then when it hits 4th it's the same thing all over again.
walnuts4x4
Watertown, NY
mine did... horribly... and no check engine light on... finally changed all cops with ebay ones... I used global automotive.. same price as UNEEK... and autolite double platinum plugs without any problems
Racenut
Deming, New Mexico
? how many miles are on the truck?
Given the year I would say at least 100k?
Alot of people do not change out the coils and plugs for:
1. Ford says it dosn't need to be done until 100k
2. They are a bit of a PITA
3. If the old owner had heard the stories of plugs being "spit out" they may not have wanted to touch them out of fear and said it is still running fine so no need.
I have an '02 with 120K + and I just changed mine for the first time because the truck was running good ( or so I thought ) the new coils made such a difference it feels like it is brand new again! Not only the coils, but the plugs ( holy crap ) the factory spec on plug gap is between .052 and .054 the plugs that I pulled out ( original to the truck ) where at .074 and the electrode looked like this /| I had never seen a plug that was worn so bad.
98EXPY 5-0
PA
This actually makes more sense to me than the transmission being the issue. The transmission ran 99% before it was parked. Perhaps even 100% is the two shudders I felt were actually one of the coils starting to go.
So a solid on CEL could mean anything, but a flashing CEL only means misfire?
I guess I have some ebaying to do.
98EXPY 5-0
PA
The truck has 260K on it, but the motor has around 120k or so. I bought it from a Police Department, and their mechanic showed me the log book and the mileage of the truck when they got the new motor was about 140k. I also don't know how much was replaced when they did the swap. They may have just used the same coils from the old motor.
I thought being a police vehicle, it would at least have been serviced at regular intervals. However, I found at least one thing that shows me the mechanic just kept it running and probably put an inspection sticker on it when he shouldn't have. The front left brake pads were worn to the metal and the front lefts looked brand new. I thought the caliper was bad. Then I found the reason. The caliper bolts were rounded off inside (allen head), so it looks like he just never changed that side. Which also might explain why they only gave me three extra rotors with the extra parts they gave me.
98EXPY 5-0
PA
It looks like his prices went up. $115 now, and $140 for the V-10 set. I might as well get them to have two extra, right? It looks like the same part number.
EDIT, it looks like he doesn't have any for a 98. Only 2004+
Racenut
Deming, New Mexico
Exactly a solid CEL is a Hard code that could be caused by anything but the Blinking CEL is a Random Misfire (could be 1 or more cylinders). You can get a solid CEL from a misfire as well but it would be a constant missfire meaning the coil is dead!
98EXPY 5-0
PA
Thanks.
UNEEK got back to me, saying that he doesn't carry the coils for my 5.4L motor? He says I need DG-473s. I thought I needed 508s?
Can some one help me out here? I would assume he would know what coil I need. But Global lists the 508s for my engine.
98EXPY 5-0
PA
Yeah those are the DG508s. I looked on Advance Auto online and they also said DG508s. I guess UNEEK was either confused by my question or doesn't actually know anything baout what he sells.
I also need to get some swivel sockets and some 1/4" drive extensions, so I'll have to wait until Friday to order the coils and plugs.
Are the Motorcraft plugs the way to go?
Racenut
Deming, New Mexico
Your truck probably came stock with the DG-473's but the cross reference replacement on them is the DG-508 most all first gen triton 2v motors (at least in the trucks) use the 508's.
As for plugs I recomend the Motorcrafts, but I belive there are quite a few people on here like Walnuts that are running the Auotlite's with no problems. Just make sure to take your time and have a TOURQE WRENCH if you do not tourqe the plugs you are asking for problems.
Interceptor
TX
My 2 cents:
I can't speak for your year/model or engine displacement, however I did plugs on my '97 F150 4.6L, which required an good selection of extensions and swivels to get at all of the plugs. The real key is taking your time and making double sure you are not cross-threading. Someone else might want to chime in on this, but some anti-seize on the threads might help in the long run too.
Racenut
Deming, New Mexico
My 2 cents:
Just make sure to keep the Anti-seize to a minimum. There are a LOT of different ways people on the net say to do the plugs. I used a very small amount of Copper coat Anti-seize and also Torqued the plugs to 26 FT LBS (I have put 5k on them and no problems).
There are 2 main ways these plugs will come out of the head, and that is cross threading the only 4 threads in the head, and not having them torqued good enough.
If you cross thread, then of course the plug will not hold for long since there are very few threads to begin with so if you end up loosing a plug you will have to have a TIME-SERT put in. Link to time-sert :
http://www.timesert.com/html/ford_sparkplug_faq.html
Also if the plugs are not Torqued enough then they can come loose and vibrate out of the hole. If this happens some times you will get lucky and not need to put in a Time-Sert, but some times you still do.
Either situation will wipe out the coil pack so make sure to keep some of your old coils for "just in case spares", or order the set for the v10 that way you have 2 NEW Spares.
If you take your time and pay attention to everything you should not have to worry about loosing a plug but with these motors unfortunatly there is always that chance.
walnuts4x4
Watertown, NY
I did use autolite double platinums and so far so good... almost a year... and no anti-seize
make sure you take your time installing new ones so that you don't cross thread... what me and DGray69 did on mine was use a spark plug socket by barely holding plug and get it started then use a regular deep-well socket to tighten them with a torque wrench... that way the socket doesn't get stuck...
if you have a harbor freight... that is were I got a variety set of extensions, swivels and a torque wrench before I started for pretty cheap..
walnuts4x4
Watertown, NY
and good luck.... take your time.... get a friend to help and have plenty of beverages of your choice during the install.... it can be done...
