Courtesy lights won't go off
rriley1947
I open the door and the interior courtesy lights come on. However, they won't go off when I close the door unless I slide the dimmer switch all the way down. The battery saver will turn them off after 10 minutes. What am I doing wrong?
Sent from my iPad using Tapatalk - now Free
rexster314
Texas gulf coast
Well, you posted twice but after you get in the truck, they'll go off as soon as you start the vehicle. You can also check the settings in your options to see how long the lights are set for
rriley1947
rriley1947
How do I check the settings? I read my owner manual and could not find that. The only thing I found was setting the timer for the day time running lights. I think I'll call a technician at my dealer.
rriley1947
rriley1947
Thanks for your help. I remembered the settings button is on the steering wheel as I had to set this for the power running boards. I found out how to turn off the lights. Have a good one.
