crank no start
Bedrck47
Elizebethtown, PA
Take your Volt meter and hook one lead to the top of the IFS switch hook the other lead to ground Then get in and try to start the engine while watching your volt meter.
See if you get a 12 volt reading when you first try to start. If the voltage then drops off I would say you have a bad pump.
Applications Using a Fuel Pump Relay for Fuel Pump On/Off Control
The Fuel Pump (FP) is a PCM output signal that is used to control the electric fuel pump. With the electronic EC power relay contacts closed, vehicle power (VPWR) is sent to the coil of the fuel pump relay. For electric fuel pump operation, the PCM grounds the FP circuit, which is connected to the coil of the fuel pump relay. This energizes the coil and closes the contacts of the relay, sending B+ through the FP PWR circuit to the electric fuel pump. When the ignition key is turned on, the electric fuel pump runs for about one second, but is then turned off by the PCM if engine rotation is not detected.
