In manual, it says to check fuse #5 7.5amp, #12 10amp and #28 5amp.
It also says to check the speed servo relay r302. But if all your fuses and relays check out your light should still light up. I read this on the internet it might help...........
(just fixed my Cruise control problem. It didn't work at all, no light in the dash either. What had happened was, I had changed the brake booster some months back and when the brake pedal is disconnected from the booster shaft, it allows the pedal to raise too high. It will contact the cruise control disconnect switch to the left of the brake switch. To find the switch, look close and there is a "L" bracket welded on the brake pedal and the cruise switch contacts this bracket. Well this switch is a self-adjusting switch designed to be installed with the pedal at least an inch or so depressed. When the pedal is released it will contact the switch and push the shaft into the switch to the determined setting and it will lock into that position. I was able to pull the shaft out enough to make contact again and it self adjusted like it's supposed to and now the system works great! What made me go to this switch was by checking power at pin 6 (blk/yellow wire) at the cruise servo connection. This connection has 6 pins and the end pins (1 & 6) both have 12 volts. Mine had no power at pin six, which means the cruise deactivation switch is the problem. Older Expeditions had this switch on the brake master cylinder (recall for fires, etc), but 2003 and up has it on the brake pedal itself. Once I figured out where the switch actually was, it was easy to figure out. )
