Cupholder Sharp Edge
fitmanyard
Chippewa Falls WI 54729
'19 Expy Stealth Max Limited. Like others have mentioned, the chrome trim around cupholders is letting loose. I've sliced my fingers open twice and now will either remove it or use a fine sand paper to take off the near razor sharp edge. Just a heads up for others once again.1000074771.jpg
Hardcase60
Central Texas
I recently found that the cupholder trim on our 2018 Max Platinum is doing the same thing. There is no need to ask how I found out... Currently trying to figure out what clamps/clamp system to use in an attempt to glue it back in place.
fitmanyard
fitmanyard
I opened armrest and started on top to start peeling it off. Sanding the edge for me did not dull it. I only took off the loose sharp area. I've included pics of what I settled on doing with the Sharpie. My Wife and I are the only ones in the vehicle 99% of the time and this will not bother us. I was slow to fill it in and in the cupholder closed pic, you can see the end result. No more sliced fingers unless it lets loose in another area. Sidenote, the material underneath feels like a hard plastic or resin material. It might be tricky to find the right primer and adhesive to glue down correctly. Good luck and let me know what worked for you. Thanks
