notamechanicbrad
Good day mates!
Ive got a misfire on cylinder 8 when I put the truck under a load. The check engine light starts flashing and continues until I let off the throttle partway. Ive changed the plug, coil and fuel injector with no improvement. I am losing some water/coolant somewhere as well. But, there is no water in the oil and no bubbles in the radiator upon startup so I am hoping the head gasket is not the problem. If I leave the truck running just sitting in the driveway I seem to get a hint of gasoline smell. Im guessing that is from an intermittent misfire while at idle. My next step is to replace the electrical plug on the injector as that wiring looks pretty rough (although I see no breaks in it) then to trace that harness back to the PCM to see if one of those wires is the possible problem.
The 3 questions I have been searching for info is ----
1. Could the head gasket be leaking water into the cylinder without water getting into the oil?
2. Is it a common problem for the intake manifold to start leaking in that #8 cylinder? Ive replaced the intake gasket on another Expy but it was leaking at the thermostat.
I try to do as much repair work myself as possible due to the fact I drive this truck from Texas to Florida twice a month pulling a trailer and it usually breaks down on the highway nowhere near a reasonably priced mechanic who is willing to do a repair almost immediately!
I do have the Forscan software as well but am not well educated in how to use it to diagnose this type of problem.
