Dashboard lights
Jae90
Hello dashboard lights went out does anyone know the fuse number to see if that is blown is an 04 expedition Eddie Bauer.or how to fix thanks
Bedrck47
Elizebethtown, PA
  1. Electrical
  • Central junction box (CJB) fuse(s):
    • 6 (15A)
    • 22 (10A)
  • Wiring harness
  • Headlamp switch
  • Dimmer module (Navigator only)
  1. If the fault is not visually evident, determine the symptom and proceed to the Symptom Chart.
Symptom Chart
Symptom Chart
Condition Possible Sources Action
  • The control illumination is inoperative
  • Central Junction Box (CJB) Fuse 6 (15A).
  • Circuitry.
  • Headlamp switch.
  • The instrument cluster illumination is inoperative
  • Bulb(s).
  • Circuitry.
  • Instrument cluster.
  • Headlamp switch
Your owners will show you the location of the fuses
If you don't have a owners manual You can download a copy at
owner.ford.com
