Originally posted by tperk100
Thanks Monsta,
If I am not mistaken, the belt minder disable only disables the repeating reminders, but not the initial reminder... Am I wrong?
I look forward to seeing your procedure on how to diable the key in minder.
Thanks
Nope, you are right. I thought you meant the repeating reminder...
sorry...
The procedure might have to wait until tomorrow morning (Hawaii time, I'm 5 hours behind EST.) I have to work this evening.
If it works on the Expy (worked on my Excursion) it is quite simple.
-Remove the plastic that surrounds the steering column.
-Under the key tumbler is a hole that an awl or someting similar can fit in.
-With the key in the ON position but the engine NOT running, put the awl in the holeand pull the tumbler out.
-You'll see a brass contact.
-Cover the brass contact with a small piece of electrical tape.
-reinsert the tumbler
-Turn key to off and make sure everthing is set in place and working.
-Replace plastic surround.
This will stop the key from setting off the chime when it is placed or left in the ignition when the ognition is OFF.
I'l post pics tomorrow.
