ICrushedAPrius
A while ago someone had asked about installing third row seating in their expy. I have a '97 and found the seat and mounting brackets from 2 separate sellers on ebay. I pulled up the carpet in the cargo area and saw that the floor already had loong ovals where the metal is usually cut out at the factory on the newer models.
I cut out the ovals with an angle grinder and dropped the brackets in. The seat fit. I drilled holes and installed bolts, sealant, and cut the holes in the carpet. (Which is not as easy as you might think!)
It's a great addition to my vehicle, and makes it a little more like my long lost Excursion : (
All in all it cost me 225 bucks and adds a bunch more removable seating.
CAUTION though! I did some research after the fact and FORD, as a disclaimer, says that third row seating without headrests is highly dangerous in a rear-end collision.
