Door adjar & back up sensor malfunction
khpony
SW Colorado
I can't get rid of the door adjar message and the check backup system mesages on my 03 Expedietion. I've sprayed the door latches, including the rear hatch, and reshut the doors many times and can't get it to go away. Am I missing something obvious? Also is there any way to disable the backup alarm system until I can figure what's wrong with it. Any help would be greatly appreciated.
stamp11127
Temple, Georgia
Signature update
Please add your Expy info(year - engine - trim) to your signature so that future questions / replies are tailored to the correct year.
I'll try to look up the answers to your questions this evening. My Win7 decided to give me a workout on the user profile this morning and has put me behind on the chores for the day.
stamp11127
Temple, Georgia
In the central junction box pull fuse F1.27 and see if anything other than the parking aid quits.
Are your running board or interior lights on with the "door ajar" light being on?
jimp
Kansas city
It does not have anything to do with the Back up aid message, but I created my own problem with the door ajar message on my 03 (interior lights stayed on). I always cleaned my doors weather stripping and hit it with silcone spray and while I was at it I alway hit the door latch with spray. This created the problem, once I figured that out and cleaned them with contact cleaner and quit spraying ANY KIND of Lub. The door problem went away. So when you said spraying the doors, with what, cleaner something else? If it is something else try a good long spray of cleaner.
K
khpony
SW Colorado
Sorry everyone been out camping for 3 daye. I'll try the remedies suggested and report back in a couple of days. I have to catch up on things here first.
Thanks!
stamp11127
Temple, Georgia
Don't pull the fuse since there is more on that circuit. I'll look into it tomorrow after work if nothing comes up.
stamp11127
Temple, Georgia
For the "door is a jar" nonsense there are 5 switches, one on each door and another on the rear glass.
Do you have a dmm - digital multimeter and know how to use it? You will need that or a test light to check each switch.
Also need an email address to send some diagrams to you.
The Parking Aid Module is sharing fuse F1.27 with a few other items so you shouldn't pull it. The module is located in the driver side rear panel just above the rear wheel. along side the speaker.
Newport News, VA
i believe there's a sticky for the door ajar...there definetly are threads on it and how to fix...rear sensor...i believe someone changed a relay or found bad wiring
Bedrck47
Elizebethtown, PA
Key in OFF position.
Disconnect: Suspect Door Ajar Switch Connector.
Connect a jumper wire between the pins of the suspect door ajar switch. Refer to the following chart:
Door Connector
LF C526
RF C602
LR C715
RR C820
Do the courtesy lamps turn off?
Yes
INSTALL a new door ajar switch. TEST the system for normal operation.
K
khpony
SW Colorado
This implys that I will need to pull the door panel to get to the switch. Is this correct? Also I've searched several times and can't find the sticky.
