Door Lock Code
G
Guest
Does anyone know the code sequence to set my doors to lock when I start driving?
I deactivated the automatic door locks but I lost the code to activate them. Can someone please help?
cnuttgirl
Terre Haute, Indiana
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and all
vehicle doors are closed.
You must complete steps 1-5 within 30 seconds or the procedure will have to
be repeated. If the procedure needs to be repeated, you must wait 30
seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete
