Dorr ajar switch
king200
1998 ford exp... the driver side door switch is bad.... The interior light stays on and also the running boards stay on when the dooor is open and closed....where is ti I cannot seem to find it...any help
jimboh247
Winston-Salem, NC
Spray the door lock area ( the area where the door latches) with WD-40. Do it to all your door locks. I had the same problem. It worked for me.
rrosenbohm
Sturgeon Bay Wisconsin
Door Ajar, key chime, dome lights
My 97 runs perfect at 112k mi. But the dome lights sometimes stay on, the door ajar plannel light is always on and now the key chime continues after the doors are closed until the ignition is turned on. All this activity has run the battery down on me twice or is the battery the problem?:confused:
K
king200
spray WD40 in all the doors locks. i know it sounds wierd but jimboh247 told me to do it and it worked. I also did the tricj on my ford winstar .....good luck
rrosenbohm
King200:
I tried it, it worked. I found out later from a Chrysler dealer that this is standard procedure on how they handl Fords with this problem.
Thanks
RR
oelkersbrian
