Driver Side Front Seat Trim Needs to be Replaced
2015owner2015
Northern California
The lower trim on the driver side front seat on my 2015 needs to be replaced. Can just this piece be purchased either from Ford or OEM?
I will try a Pick n Pull as well.
The seat is showing its age, so maybe I should just replace.the entire seat, that would be another approach.
Thanks for any advice!
99WhiteC5Coupe
BlueStangGT
Oklahoma
Here's what I did to mine...
seat_fix06-jpg.37922
And a link to the thread I made:
Driver Side Seat Trim Panel | Ford Expedition Forum
2015owner2015
2015owner2015
Northern California
I think my original zip tie fix caused the additional damage.
Besides jury rigging it, is the only fix to replace the seat at this point?
Btw, my solution will probably be to jury rig it :)
Swede252
Pennsylvania
Hello,
I fixed my panel by adding countersunk screws 2 years ago.
I just took my time to locate the steel behind the trim and went thru while I held the part in place. I then tapped the threads.
I did this because even with the new part acquired, you will most likely break again anyway. It’s not as sturdy as it needs to be, you stress this part every time you get in and out so....
Good luck...
So.. I took the pictures, it’s rainy here too..
So the lower screws are just thru the plastic. They are shorter, just long enough to reattach both pieces together. The top right is like a 1/4-20 or metric equivalent that I started with a smaller screw and up sized it for strength that is into the steel frame. I haven’t worried about ever again so.. but countersinking them make it better and I was looking for some matching paint but never got around to it...upload_2021-5-24_22-20-35.jpeg
juan214
Stoughton, MA.
Double check the info below just in case.
Part Number: GL1Z14A707AA
Supersession(s): FL1Z-14A707-AA; FL1Z14A707AA; GL1Z-14A707-AA
YOUR PRICE $51.67 MSRP: $71.17
If it were not available I like BlueStangGTs option as well.
