Driver's side front window refused to go up for a minute? Eh?
NewbieVet
Knoxville
Was at a light earlier today and went to put my drivers window up cause I'd just finished smoking (yeah I know, shouldn't be smoking in the truck but I'm a punk). Anyhow I pressed the button and got no response. Checked all the other windows and they were fine, then tried again and again for the drivers window and nothing. On about the 10th try it went up nice and smoothly like nothing had been wrong and has worked ever since. What's up this this? No mechanical noise, nothing...
Quick point of interest. Both button lights (the green glow which illuminates the front windows on my door control panel are out and have been since I bought the truck). Wasn't a big deal to me and my buddy said I'd need to replace the entire module under there if I wanted to get them fixed so I passed..any relationship to the above issue?
offroadexpy
I would just get on ebay if I were you and buy a new switch module, I see them on there all the time and fairly cheap too...
tallsville
LA
happens to me every once in awhile. if haven't done this. but you can take apart the module and try cleaning the contacts. or as offroad says buy a module off ebay.
NewbieVet
NewbieVet
Knoxville
weird. Looked on ebay and didn't find a single one. Maybe it's that time of year? lol
ELVATO
Orlando, FL
Take it apart and clean it with electric parts cleaner. Or, just push it harder. Or just get a new switch.
There's a bunch on ebay: Link. Seems they're all going for around 50 bucks new.
As for the LEDs, the circuit board sucks. They put in a bunch of surface mount resistors to reduce the voltage from 14.4 to ~5V, so it gets kinnda hot in there, and messes up the "wiring" within the PCB. I had a video on the other site where I took the switch apart. You can see the LEDs still work if you push down on certain sections of the PCB.
Heh, really just Ford electronics :p
panda24619
San Diego
my gfs dads fx2 does that. i forgot the year, but i think its an 08 or 09 f150. the switch seems to get stuck going up. you press it a few times and it works. he just deals with it.
NewbieVet
NewbieVet
Knoxville
Thanks for the link. I was typing switch module so wasn't getting any hits. Cheers!
NewbieVet
NewbieVet
Knoxville
These are great vids man! Actually makes it look fairly simple (minus all those pesky tabs!) I assume you have to remove the board before you can actually replace the leds tho? Does that jump come up by using a pair of needle nose to pop the two remaining pins? Thanks again for some well put together how-tos!!!
J
