Remove door panel, remove the plastic liner that is behind the door panel. if the glass is all the way up, tape the glass in place using some duct tape or other "super sticky" tape (masking tape does not count). At this point, undo the two bolts at the base of the glass. Slide the metal bar away from the glass and lower the bar out of the way. Rotate the glass slightly (removing the tape, but supporting it with your hands), and then lift up to pull the glass from the door. You may find it easier to remove the weather seal from the outside of the door. No required, but does make it a bit easier. From there. reverse the steps and install the glass.
Having a second person with you does make it easier, but can be done by a single person.
